Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 07-25-2005, 11:23 AM   #1 (permalink)
Photos: 0
stealthsmooth is an unknown quantity at this point
hello all
my air light is staying on. is this a common problem? how can i sort it?
stealthsmooth is offline   Reply With Quote
Old 07-25-2005, 12:42 PM   #2 (permalink)
Photos: 0
Scotty Dangles is an unknown quantity at this point
Originally posted by stealthsmooth@Jul 25 2005, 10:23 AM
hello all
[snapback]365019[/snapback]
Ya...bimmers will do that to you...shouldn't be a problem...mine is flashing now as well...but thats because I didn't disconnect my battery when changing my bulbs in the dash... ghead
Just bring it in and have them reset it...that should do it...but then again maybe there is a problem...but highly unlikely...
Cheers
Scott
Scotty Dangles is offline   Reply With Quote
Old 07-25-2005, 01:13 PM   #3 (permalink)
Photos: 0
Originally posted by Scotty Dangles+Jul 25 2005, 10:42 AM--><div class='quotetop'>QUOTE(Scotty Dangles @ Jul 25 2005, 10:42 AM)</div><div class='quotemain'><!--QuoteBegin-stealthsmooth@Jul 25 2005, 10:23 AM
hello all
[snapback]365026[/snapback]
[/b][/quote]
Did you bump the wheel or disconnect anything from the column? I've worked with mine without the batt. disconnected and have had no issues. Man... that sucks :P
Just go to the dealer (unless you have a diagnostic / reset tool for more than just engine codes) and have them check it out and reset the light if nothing is wrong.
The light just randomly popped up on my e39 one day... really wierd, too lazy to fix it though. haha
Old 07-26-2005, 05:57 AM   #4 (permalink)
Photos: 0
myu lights has been on for ages. tried the reset tool but no hope. it needs plugging into a machine. could be the pad on the passenger seat. ? its been on for ages now but i think i need to sort it out. seeing that light pisses me off. it could even be the sensor?/
Old 07-26-2005, 08:55 AM   #5 (permalink)
Photos: 0
[snapback]365174[/snapback]
...you can always remove the light bulb for the SRS signal from the dash...
Old 07-26-2005, 02:09 PM   #6 (permalink)
Photos: 0
For safety reasons, just get it checked out. If it's a sensor, the bags may not work properly. Thats no good.
Old 07-29-2005, 01:28 AM   #7 (permalink)
Photos: 0
spdstrsam is an unknown quantity at this point
hello all
Cheers
Scott
[/b][/quote]
spdstrsam is offline   Reply With Quote
Old 07-29-2005, 01:39 AM   #8 (permalink)
Photos: 0
hello all
Ya...bimmers will do that to you...shouldn't be a problem...mine is flashing now as well...but thats because I didn't disconnect my battery when changing my bulbs in the dash... :banghead
Cheers
Scott
[/b][/quote]
Scott: I have the same problem as you did - changed bulbs today in my dash without disconnecting batttery...did it in two cars. Results: flashing SRS light in each.
I'll have them reset on Monday. Thank yo for sharing the info. Regards, Sam
'92 525i 5-speed, '93 525i automatic. Luv 'em both but am really nuts about the 5-speed!
Old 07-29-2005, 05:00 PM   #9 (permalink)
Photos: 0
paulicus is an unknown quantity at this point
Originally posted by stealthsmooth@Jul 25 2005, 03:23 PM
hello all
This is a very common problem, usually it is a faulty wire under the front seat, fix for the dealers.
They need to reset the onboard computer to kill the light as well.
paulicus is offline   Reply With Quote
Old 07-29-2005, 05:38 PM   #10 (permalink)
Photos: 0
hitz is an unknown quantity at this point
Originally posted by paulicus+Jul 29 2005, 03:00 PM--><div class='quotetop'>QUOTE(paulicus @ Jul 29 2005, 03:00 PM)</div><div class='quotemain'><!--QuoteBegin-stealthsmooth@Jul 25 2005, 03:23 PM
hello all
my air light is staying on.* is this a common problem? how can i sort it?
[snapback]366070[/snapback]
[/b][/quote]
sometimes it makes u think is BMW as good as it meant to be?
hitz is offline   Reply With Quote
Old 07-31-2005, 01:03 PM   #11 (permalink)
Angelic0-'s Avatar
Photos: 0
Angelic0- is an unknown quantity at this point
Send a message via MSN to Angelic0-
A friend of mine had this light flashing for a week, and i told him this also happened in my mom's Golf... a week later the airbags blew out when parking the car... lucky he wasnt going fast... so i'd get that checked !
| BMW E36 325i | BMW E34 520i | BMW E39 "M5" | BMW E60 530d MAPPED | BMW E38 740iA | BMW E32 750iAL |
Originally Posted by Mazi!
Viktor :|
Angelic0- is offline   Reply With Quote
Old 09-30-2005, 11:09 PM   #12 (permalink)
Photos: 0
HardStep is an unknown quantity at this point
Hi guys,
i've heard there is a way to bypass the passenger seat sensor (to make sure it will not break again...). Is there a some kind of instruction on doing that bypass trick somewhere (and resetting the light with Peake airbag tool afterwards)?
HardStep is offline   Reply With Quote
Old 10-05-2005, 03:29 PM   #13 (permalink)
Photos: 0
eugene is on a distinguished road
Exclamation air bag light
Please help ! 97 bmw 528ia air bag light is on after ( accident) I change right side air bag, how to fix? make reset ? Can I do that by my self?
eugene is offline   Reply With Quote
Old 10-05-2005, 06:23 PM   #14 (permalink)
68th gear and shifting
superdeadman's Avatar
Car: a lot of broken ones
Photos: 0
superdeadman has a spectacular aura aboutsuperdeadman has a spectacular aura aboutsuperdeadman has a spectacular aura about
Send a message via AIM to superdeadman
eugene --- either go through dealership to reset it or buy air bag reset tool for like 100 bucks... its sold all over internet, including ebay
R.I.P. fast 6
"drive hard
keep it clean
superdeadman is offline   Reply With Quote
vB code is On
"help! I Want Better Headlights On My 3er!" jlevi 3-Series (E46, E90) 43 09-25-2008 08:34 PM
*The E36 Turbo Thread* SpeedInfusion 3-Series (E36) 9 10-16-2005 10:10 PM
air bag light eugene 5-Series (E12,E28, E34, E39, E60) 2 10-10-2005 12:27 PM
COMPUTER CHECK - TAIL LIGHT FAILURE?!?? kraze0g 3-Series (E36) 3 06-25-2004 11:30 PM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
