Ac Compressor - BMW Forum - BimmerWerkz.com
Old 10-25-2004, 03:49 PM   #1 (permalink)
Beamer5 is an unknown quantity at this point
Guys, the compressor on my 98 528 sport is making a clicking noise. I took it in and was told that my compressor was going out and was quoted $1200 for the repair. Should I let the dealer repair it or is there a better/cheaper way to take care of this problem? Open to any and all suggestions!
Beamer5 is offline   Reply With Quote
Old 10-25-2004, 05:05 PM   #2 (permalink)
LOS
LOS's Avatar
Car: 97 540IA, 95 840CI
At least you know what the problem is. Get more quotes from other shops and do some cost comparison.
Good luck
LOS
Old 10-25-2004, 05:36 PM   #3 (permalink)
billB's Avatar
Also you may want to consider a used one from a wreck. I got a whole engine came out of 99/528I with 43.000 miles on it. Real cheap and works perfect.
regards
Old 10-25-2004, 06:59 PM   #4 (permalink)
Speedy-325is's Avatar
i have the ac compressor from my 325i, i dont use it and was going to take it out tonight...if it is the same, make me an offer...
Mark
Old 10-31-2004, 09:32 PM   #5 (permalink)
canambmw is an unknown quantity at this point
:help
[snapback]218253[/snapback]
Before you replace the A/C comp - check the idler pulleys and tensioners. Unless the car has 150K + the A/C unit is pretty stable. The idler pullys and tensioners are suspect after 70K.
JM
canambmw is offline   Reply With Quote
Air Compressor And Tools nookatee 3-Series (E36) 2 06-27-2005 01:14 PM
R-134a Conversion bkcraun 3-Series (E36) 5 01-10-2005 07:46 AM
A/C Compressor Rumbling chris3 3-Series (E21, E30) 1 09-12-2004 12:35 PM
R12 or R134a? greenlightracer 3-Series (E21, E30) 8 06-25-2004 06:30 PM
UK Spec '97 E39 523i SE A/C - Compressor Make? NickC 5-Series (E12,E28, E34, E39, E60) 0 05-04-2004 09:50 AM
