Abs Module - BMW Forum - BimmerWerkz.com
Old 01-27-2005, 10:29 PM   #1 (permalink)
Pat O'Brien is an unknown quantity at this point
Any one ever had a ABS/ASC module go bad on 5series 99? I'm getting a warning light ASC & ABS coming on after I drive for a while or sometimes when I first start up.
Pat O'Brien is offline   Reply With Quote
Old 01-29-2005, 07:52 PM   #2 (permalink)
billB's Avatar
[snapback]280821[/snapback]
What makes you conclude it is a bad module? This light can be triggered by a host of other things including mismatched rear tires!!!
Old 01-30-2005, 11:16 AM   #3 (permalink)
Originally posted by billB+Jan 29 2005, 07:52 PM--><div class='quotetop'>QUOTE(billB @ Jan 29 2005, 07:52 PM)</div><div class='quotemain'><!--QuoteBegin-Pat O'Brien@Jan 28 2005, 05:29 AM
Any one ever had a ABS/ASC module go bad on 5series 99?* I'm getting a warning light ASC & ABS coming on after I drive for a while or sometimes when I first start up.
[snapback]282049[/snapback]
[/b][/quote]
Old 01-30-2005, 11:22 AM   #4 (permalink)
[/b][/quote]
Your right I don't know....I'm relying on a mechanic that I think I can trust. I didn't know mismatched tires could cause this problem but in this case the tires are the same.
Old 01-30-2005, 11:52 AM   #5 (permalink)
billB's Avatar
Originally posted by Pat O'Brien+Jan 30 2005, 06:22 PM--><div class='quotetop'>QUOTE(Pat O'Brien @ Jan 30 2005, 06:22 PM)</div><div class='quotemain'>
[snapback]282398[/snapback]
[/b][/quote]
This is what I would do 1st.
A. Get it hooked to a diagnostic tool, pull the code it can be as easy as front/rear speed sensor/wiring going south. Many places will perform this for free i.e. autozone.
B. Disconnect your battery (-) terminal for a while then reconnect..to reset all electronics...see what happens. But make sure you have you radio code if required
P.s. the above mismatched tires was only an example to show you this ASC button (center console) does control your traction in a mechanical and electronic sense.the latter does so by controlling/cutting your engine/throttle.
p.s. The ASC button itself goes through torture by all kind of drinks from the cup holders!!
good luck
HELP - Brake, ABS, and DSC lights on Fangs 3-Series (E46, E90) 48 05-13-2011 01:39 PM
ABS System failure!!Advise needed please. BMWstealth 3-Series (E46, E90) 9 10-12-2005 08:20 PM
Check Control Module? djianlaverick 3-Series (E36) 2 04-01-2005 09:30 AM
On Board Computer Module Inside The Car Q_BMW 3-Series (E36) 1 10-30-2004 04:48 PM
Remote Starter RFredeking Audio and Electronics 12 05-18-2004 07:30 PM
