Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 04-04-2008, 06:53 PM   #1 (permalink)
Photos: 0
rmory is on a distinguished road
ABS light, brake light and TCS offline on 528i... ideas?
I have a 2000 bmw 528i. The ABS light, brake light and traction control light are on. There are 2 stored codes on the vehicle. #105 - brake pedal switch signal and #115 - pressure sensor signal interference. Neither of the repair information systems at the garage have fault diagnosis for these fault codes. Any ideas what may be wrong?
rmory is offline   Reply With Quote
Old 04-05-2008, 04:02 PM   #2 (permalink)
winters97E39's Avatar
Car: 1997 BMW 528i
Photos: 0
winters97E39 is a jewel in the roughwinters97E39 is a jewel in the roughwinters97E39 is a jewel in the rough
Send a message via ICQ to winters97E39 Send a message via AIM to winters97E39
Have them reset the codes. If those same lights don't come on again until your car moves, it could well likely be a wheel speed sensor problem.
What are the P codes from those that are showing? I can't find those in my bentley manual.
Jason / 1997 528i
winters97E39 is offline   Reply With Quote
Old 04-08-2008, 11:15 AM   #3 (permalink)
Photos: 0
dannydayz is on a distinguished road
with bmw's with those three codes on...it is usually the abs control module....replace and code....to test ...look at live data...if inputs are working for those that codes were set then replace abs control module....
dannydayz is offline   Reply With Quote
Old 06-15-2008, 07:27 PM   #4 (permalink)
Photos: 0
nelson8664 is on a distinguished road
9 out of 10 times that is the abs control module i have the same problem
nelson8664 is offline   Reply With Quote
Old 06-16-2008, 12:39 AM   #5 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 99 C43 AMG, 89 300SEL
Photos: 0
Send a message via Yahoo to darkhorse737 Send a message via Skype™ to darkhorse737
Lightbulb
105 is a given-check switch and cabling.
115-before you go changing parts...
1)check brake fluid levels; and make sure ABS is bled and properly purged.
2)signal interference can also be caused by dirty or failng brake sensors.
traction control takes it's inputs from the same sensors so i suggest you start there.
* sensors, modules, brain/s... these are electronic systems and just like your PC are prone to glitches. (i.e. a static charge at the sensor level or a surge in the module is enough to trigger the "check lights") If your mech or tech is a friendly 1 and looks after ur interest, the proper way to do this, is to clear the light at least a couple times... lucky you if it goes away. if it doesn't, then that is the time u take corrective measures :-)
Old 08-14-2008, 11:01 AM   #6 (permalink)
eddy_rooney's Avatar
Car: e39 528i M-sport thingy.
Photos: 0
eddy_rooney is on a distinguished road
Send a message via MSN to eddy_rooney
Hi guys, my e39 has the traction control light also the abs light on. the cruise control also was not working but i had a fiddle with the rear speed sensors and the lights are still on but the traction control light now comes on. it didnt do that before. so im thinking maybe the system just needs resetting???? what do you think? any ideas?
eddy_rooney is offline   Reply With Quote
vB code is On
Brake Light Circuit And Tail Light Failure 325is1994 3-Series (E36) 7 08-05-2008 01:00 PM
ABS, DSC, and Brake light stay on.... cub_fever 3-Series (E46, E90) 0 09-04-2007 02:01 PM
E39 528i Brake Light amitpatel 5-Series (E12,E28, E34, E39, E60) 9 04-18-2006 12:39 AM
318is - Abs Light / Abs Pump Noise jonathan82 3-Series (E36) 0 08-31-2005 05:52 AM
'94 318is: brake light & fog light question ultraviolet353 3-Series (E36) 2 08-14-2004 02:46 AM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
