Abs/asc Light On 2000 523/525 - BMW Forum - BimmerWerkz.com
Old 10-15-2004, 12:40 PM   #1 (permalink)
Avatar1 is an unknown quantity at this point
Hello guys, I really need help as I am at the end of the rope with my vehicle:
I have a 2000 523ise (525 engine) manual 5 speed.
The car is equipped with ABS and ASC. A few months back the ASC/ABS light went on, and when I put it on the scanner it said Rear Left Speed Sensor.
So naturally I changed the sensor and shortly after the light came back on...
Back on the scanner - Left Rear Speed Sensor Circuit......and the speedo does not work; So:
1. Cleaned the sensor's ring
2. Checked wiring visually
3. Checked that all tires are made by the same manufacturer and have similar thread thickness
So I went into troubleshooting mode....abserving the car carefully and this is what happens:
1. When you start the car in the morning - the light is off - speedo works....upon driving it a little distance (about 15 minutes or so) the light will come on.
2. If you start the car and just leave it running the light will come on without moving the car after a little while 15-30 min or so.
3. If you unplug the wire plug from the ABS pump/modulator - and then put it back on the light will dissapear and the car will run normally for an amount of time (again about 15 min or so) before coming back on.
4. I removed the modulator off the pump (6 screws) and cleaned the inside out with aircraft electronics cleaner(**great stuff) - replaced the modulator on the pump - and the light stayed off for what looked like about 15-30 mins or so.
I dont know what to do much more than that. Can someone PLEASE help me, I need to fix the car ASAP for a driving test - which cant be taken without the speedo working. Any ideeas would be appreciated. Thanks.
Avatar1 is offline   Reply With Quote
Old 10-15-2004, 07:47 PM   #2 (permalink)
billB's Avatar
Avatar1
1. The above problem makes me think you have A THERMAL EFFECT on the hydrolic unit itself. It sounds like the ABS unit probably has a fault which causes it to shut down ONLY when it gets hot (see 1 and 2 above.... after 15-30 minutes). you can further test it by applying different temps i.e. heating/cooling the hydrolic control unit itself. If so it may need to be reprogrammed (I am afraid by the dealer only) if not changed.
2. Also you said you Cleaned the sensor's ring
Take a look inside the hole of the sensor (where the sensor came out of) and you will notice a tiny wheel with holes in it then spin and look for anything foreign on it. As you may well know these sensors are magnetic. So too much of any stuff on that tiny wheel will throw your reading off causing all kind of unplausible readings/ calculations on the computer.
P.S.
A.The above assumes all your sensors are in perfect condition since they are the primary cause of this problem. Just make sure
B. ASC light is also related to your differential+Throttle control+tranny. In fact when your car skids it cuts the throttle even if you floor it.
Good luck and please let us know of the outcome
regards
billb
Old 10-16-2004, 08:49 AM   #3 (permalink)
Originally posted by billB@Oct 16 2004, 12:47 AM
Avatar1
P.S.
regards
billb
[snapback]211943[/snapback]
I have diagnosed the problem.
HERE'S HOW TO SEE IF IT'S THE ABS CONTROLLER UNDER THE HOOD OF THE CAR:
1. GOTO AN OFFICE SUPERSTORE AND BUY A CAN OF COMPRESSED AIR
2. RUN THE CAR UNTIL THE LIGHT COMES ON
3. USE THE SPRAY UPSIDE DOWN AND SPRAY LIQUID OXYGEN ON THE UNIT UNTIL IT IS COLD (COLD COLD NOT EVEN ROOM TEMPERATURE)
4. IF THE LIGHT GOES OUT - ITS THE ABS CONTROLLER
THANKS EVERYONE!
How To Tell Options With Vin? cm70man 5-Series (E12,E28, E34, E39, E60) 18 12-31-2010 01:05 AM
