ABS, ASC & gearbox problems - BMW Forum - BimmerWerkz.com
Old 03-19-2010, 05:01 PM   #1 (permalink)
Car: 1997 E39 528i sedan
tezza07 is on a distinguished road
Need help with my '97 528i. I replaced front struts and bearing hubs and now the auto gearbox isn't changing past 3rd and abs & asc lights are on. Front sensors tested OK. Can anybody tell me which sensor affects what? Front right sensor connector has seen the ravages of time otherwise OK. Could the strobe strip on the new bearings be causing the problem? Does anybody have an opinion? The lights go out on startup but re-appear after a couple of minutes.
tezza07 is offline   Reply With Quote
Old 03-21-2010, 05:28 PM   #2 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 95 525i
Cool
check whether the hubs are specified for you car... all wheel sensors feed info on the ABS/ASC brain, and any fault can be read by a scanner so you best check them individually. OR,
better option is have the car scanned - it will tell you which sensor in particular is causing your problem.
Old 03-27-2010, 10:04 PM   #3 (permalink)
J8291197 is on a distinguished road
I have a similar problem I have to change gears like a manual but my tranny is an automatic abs light and asc light is on. The only thing is I have no idea what changes were done to the car before I got it. Someone said my abs pump is probably bad. Is there any way to check it?
Scanned it and no codes came up!
Help us out if possible tired of changing gears.
J8291197 is offline   Reply With Quote
Old 09-06-2010, 03:12 AM   #4 (permalink)
Thanks to everyone who replied. Problem solved..............had the car scanned & was told "RH front wheel speed sensor missing", had a '99-2003 sensor, replaced it and lo & behold, gearbox back to normal. Lights still on but should clear OK when I receive software for my laptop. Easiest fix since I got the car. Some you win, some you don't!!
Once again thanks all!!!!
Old 09-06-2010, 09:38 AM   #5 (permalink)
Glad it's sorted!
ABS and ASC need help pnce 3-Series (E46, E90) 4 01-13-2010 03:13 AM
Speedo lost - ABS & ASC lights on arh 5-Series (E12,E28, E34, E39, E60) 3 07-21-2007 01:43 PM
Asc+t & Abs Light sruments 3-Series (E46, E90) 2 02-10-2005 11:41 AM
Abs/asc Problems a_ok2me 5-Series (E12,E28, E34, E39, E60) 9 11-22-2004 08:51 PM
ABS and ASC lights Henri 3-Series (E36) 10 09-01-2004 01:04 AM
