98 540i question - BMW Forum - BimmerWerkz.com
Old 12-04-2009, 05:46 PM   #1 (permalink)
MBruns is on a distinguished road
98 540i question
I looked at a very clean 540i today, the orig.owner disclosed all that knew to be an issue with the car and most were very common issues for the model and mileage,one of the odd issues with the car running turning the steering wheel to the right full lock then returning to center it will die and all electrical quits, if you slowly continue back to center from where it quits the dash and electrics come back to life and you can restart it, You can repeat the problem so I am thinking a connection at the ign. switch or bad switch , he also mentioned a battery draining issue over a week or so surfaced about the same time. Any thoughts
Mike
MBruns is offline   Reply With Quote
Old 12-05-2009, 02:22 AM   #2 (permalink)
Car: 1997 E39 540i
harryinsaudi is on a distinguished road
Well i'd be thinking that you've some sort of interference between the steering column and the ignition switch cable.... Can't see any other connection.... good luck with it.
harryinsaudi is offline   Reply With Quote
Old 12-05-2009, 04:53 AM   #3 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
Could possibly be the ignition switch or more likely to the slip ring, hard to say until taken apart, buts it nothing to serious, easy fix I would say, of course be careful driving it if it cuts out when you turn the wheel.
Old 12-05-2009, 06:31 AM   #4 (permalink)
540i
Thanks, Is there a site with an exploded view of the the column and switch assy., With the telescoping steering is there a slip ring for the contacts from the switch ? When I purchase this thing I will remove the plastic and do the wiggle test on the switch/wiring, as abrupt as the condition is it should be obvious, plus there is no smoke so the chances of a direct short look slim.
Thanks again, Mike Bruns
Old 12-05-2009, 06:50 AM   #5 (permalink)
marti5's Avatar
Try here:
RealOEM.com Online BMW Parts Catalog
Just click on enter site and key in the details....
As for the slip ring its part of the steering wheel, this is how all the buttons get their power etc, the switch is a black rectangular box which you will see when you drop the cowl.
540i E34 a/m switch question blackkntyecnc 5-Series (E12,E28, E34, E39, E60) 6 03-18-2009 12:19 AM
03 540i intake question help, need help fast aapatel 5-Series (E12,E28, E34, E39, E60) 0 09-22-2008 01:40 PM
540I question Jakers 5-Series (E12,E28, E34, E39, E60) 9 04-29-2006 08:30 PM
Tire Size Question - E39 540i HardStep 5-Series (E12,E28, E34, E39, E60) 2 05-06-2005 11:36 PM
2001 540i question ali 5-Series (E12,E28, E34, E39, E60) 10 06-19-2003 11:56 AM
