98 540i electrical problems - BMW Forum - BimmerWerkz.com
Old 04-22-2009, 12:16 PM   #1 (permalink)
katscorp is on a distinguished road
Unhappy 98 540i electrical problems
Hi. got a dandy problem, i think.....
Sterio will not work along with all controlls on the steering wheel, signals and all that work but no horn, illuminasion of buttons, volume and cruz control do not work.
after a few days, everything was working again, then it all quit and same probs.
the car starts and drive fine.
I have checked all the fuses and they are good.......any suggestions?
Thanks
katscorp is offline   Reply With Quote
Old 04-22-2009, 12:31 PM   #2 (permalink)
There's evidently a loose connection in the column. Does the car have an airbag, and has that been serviced?
Old 04-22-2009, 01:13 PM   #3 (permalink)
Yes it does have airbags, It hasen't been serviced scince I have owned it. ( 9 months)
I understand the steering wheel not functioning properly because of a loose wire but would that cause the radio itself not to work?
Thanks
Old 04-22-2009, 02:17 PM   #4 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
I would be looking more at the ignition switch, which is not the barrel but is an electrical switch at the end of the barrel........common fault.
Old 04-22-2009, 11:25 PM   #5 (permalink)
Sometimes it works nd other times it doesn't. No real pattern just weird. I'll get it checked out and let you know.
Thanks
Old 04-22-2009, 11:58 PM   #6 (permalink)
CosmosBlack's Avatar
Car: 2002 Porsche C4S
marti is right, it could well be the ignition switch, a common problem.
I don't know if it's the same in a '98, but you should also look at the fusible link, by the battery. They get loose or corrode over time, causing similar symptoms.
Old 05-26-2009, 09:34 AM   #7 (permalink)
Thanks everyone! it was the ignition switch.
Old 05-26-2009, 09:54 AM   #8 (permalink)
Glad to see you got it sorted!
electrical problems chrism_88 Z3 / Z4 /ZM 2 07-20-2008 10:03 AM
Electrical problems jrsbmw 3-Series (E21, E30) 5 02-08-2007 09:12 PM
Electrical Problems Duge 3-Series (E36) 12 04-30-2005 05:41 PM
Electrical Problems Edrandall79 3-Series (E21, E30) 4 05-31-2004 11:41 AM
Electrical problems Hamann 325i 3-Series (E36) 0 10-06-2003 09:42 AM
