97 540i, Heater On Driver Side, Not Working - BMW Forum - BimmerWerkz.com
Old 12-15-2004, 07:48 AM   #1 (permalink)
///Matt's Avatar
Smile
Ok, another fun problem on the "now beginning to give me an ulcer" 97 540ia. This morning, for probably the 10th time, the heater will work perfectly on the passenger side, while im freezing my A$$ off from the driver's seat. Bringing the temp on the drivers side actually will increase the air temp....has anyone else had this problem? The heat on the passenger side is fire hot, but maybe 75* tops on the drivers...
regards,
Old 01-13-2005, 07:55 AM   #2 (permalink)
///Matt's Avatar
Happened again today.....any ideas?
Old 01-17-2005, 09:36 AM   #3 (permalink)
dberger's Avatar
dberger is an unknown quantity at this point
Today I had your same problem on a 1998 528i. Just turned around, I get heat on the driver's side while freezing air blows on the passenger side. Bad heater valve?
If you have fixed your problem, please let me know how.
Dan
dberger is offline   Reply With Quote
Old 01-17-2005, 12:53 PM   #4 (permalink)
Moderator
Dirty_Tool's Avatar
Maybe hot water valve is sticking.
Link from e38.org (for an e38 but similar)
DT
Old 01-17-2005, 07:45 PM   #5 (permalink)
njtech is an unknown quantity at this point
bad heater valve.
njtech is offline   Reply With Quote
Old 03-11-2005, 11:16 AM   #6 (permalink)
///Matt's Avatar
Just a follow up...
You were all right....A bad heater valve and $200 later, my heat works.
Thanks guys!
Old 03-13-2005, 09:41 PM   #7 (permalink)
dberger's Avatar
My heating problem is fixed. It was a leaking coolant and I had the thermostat and housing replaced. Heat is good......
Dan
Old 03-14-2005, 07:59 PM   #8 (permalink)
///Matt's Avatar
Son of a Bi!$#
Today, just 2 days after the heater pump is replaced...what happens again? No heat on the driver's side. (which would switch to heat on drivers and cold on passenger) I went by BMW and they've scheduled me in for ANOTHER appointment....I'm close to just buying a propane torch and lighting it in the car....Any other suggestions as to why this is happening???
Old 04-04-2005, 09:59 AM   #9 (permalink)
///Matt's Avatar
PROBLEM FIXED:
BMW Faxed the the following...
CUSTOMER FEELS HOT AIR ON ONE SIDE AND COLD AIR ON OTHER
BOTH SIDES SET ON SAME TEMP. FULL AUTO.
SEE HISTORY
HEATER HOSES HAD BEEN CHANGED ELSEWHERE AND WERE REVERSED AT THE FIREWALL.
(WATER VALVE CONTROL WAS REVERSED AND UNABLE TO
RESPOND CORRECTLY TO HEATER SENSOR INPUTS)
CHECK IHKA OPERATION. CHECK FAULTS. NONE STORED.
CORRECT HEATER HOSE POSITION AT FIREWALL.
TOTAL INVOICE 0.00
I'm just glad that they've fixed it....now that its 75* outside....
Intermitient Operation Of Drivers Side Door Window mudilik 5-Series (E12,E28, E34, E39, E60) 1 08-18-2005 09:56 PM
Driver Side Window Problem Crispy222 3-Series (E36) 6 03-11-2005 03:23 PM
Driver Side Door Lock Getting Stubborn ultraviolet353 3-Series (E36) 8 01-15-2005 07:37 PM
Driver Side Window Won't Seal bren 3-Series (E36) 3 07-07-2004 11:13 AM
2003 540i, Sound Not working.. youngceo Audio and Electronics 4 06-03-2004 05:20 PM
