97 528i won't start after trying to fix keys - BMW Forum - BimmerWerkz.com
Old 02-07-2004, 09:36 PM   #1 (permalink)
skorpiond is an unknown quantity at this point
Thumbs up
Guys I need huge help...
I was hanging out in my car and came home to get ready to keep hanging out, so the car was running perfectly fine... Anyways.....I have a 1997 528i and my only keys had the button that locks and unlocks the doors kind of pushed in. I took apart the keys to fix the button, which i did. But the problem now is that the keys unlocks and locks the car, but when i put the keys in the ignition and turn it, the car won't start WHYYYYYYYY?
Again the keys locks and unlocks the car, so what did i do wrong?
I would really appreciate any response. Please email me any responses to skorpiond@optonline.net
thanks
Dannye
skorpiond is offline   Reply With Quote
Old 02-07-2004, 09:45 PM   #2 (permalink)
TECH's Avatar
The key transmits a code to the EWS module, so that it will start. If this code is not received, the car won't start. You may have damaged the key.
It's possible that initializing the key might work, it's worth a shot.
Check out this FAQ I wrote for the procedure..
http://www.bmw-forums.com/forum/inde...showtopic=7877
Old 02-08-2004, 12:19 PM   #3 (permalink)
EXtech's Avatar
what probably happened is that you removed the battery for longer than 10 seconds. Whenever you do this, the key loses it's coding. It then has to be re-initialized. So re-initialize it and you should be fine.
STETT Performance -
Everything BMW
921 J Place, Suite 200
Plano, TX 75074
469-767-3309
OEM Repairs and Maintenance
Extended Warranty Service
Pre-Purchase Inspections
EXtech is offline   Reply With Quote
Help E39 Won't Start SKT174 5-Series (E12,E28, E34, E39, E60) 12 07-25-2009 10:03 AM
Why Won't She Start? nicolecass81 3-Series (E36) 4 11-09-2004 05:38 PM
528i Will Not Start Intermitenly Help mike mulligan 5-Series (E12,E28, E34, E39, E60) 4 09-27-2004 07:20 AM
325I won't start in heavy SUNLIGHT 325iconverted 3-Series (E21, E30) 3 07-09-2004 12:15 AM
car won't start euro323 3-Series (E36) 14 03-31-2004 03:42 PM
