'97 528i power seat problem - BMW Forum - BimmerWerkz.com
post #1 of 9 (permalink) Old 05-27-2004, 12:03 AM Thread Starter
ebotdm is an unknown quantity at this point
Hello all,
I have a 1997 528i. The power seat on the driver side has 3 memory positions but for some reasons they seemed to stop working about a year ago. Since my wife is the primary driver of the car and the problem is not that big of a deal, we just ignored it. But yesterday a strange thing happened. After my wife started the car, the power seat (driver) pulled itself all the way forward and the back also folded all the forward then quit working. We can still use the control to move the seat back and forth, but the control switch for the back of the seat is completely dead. I can't do anything to make the back of the seat fold back.
Anyone who might have ran into a problem like this and can shed some light on it, i would appreciate it.
Also, the volume control knob on the radio stopped working about a month ago. Since then, the only way we could control the stereo volume is by using the steering wheel control. I would appreciate it if anyone can share the fix for that also.
Thanks!
ebotdm is offline
post #2 of 9 (permalink) Old 05-27-2004, 10:06 AM
ex owner/admin
Furious's Avatar
Quoted: 1 Post(s)
quite simply put you need to take it to a professional to sort out the problem. its quite common for power seats to do something, ive seen some that have tried to move forward only half wants to move while the other half stays. quite a mess and a difficult fix if the motor is out or if you have a botched wire somewhere. if you need it fixed asap , than a good trusted mechanic is what you need.
Furious is offline
post #3 of 9 (permalink) Old 05-27-2004, 08:28 PM Thread Starter
Thanks for the reply. the local dealer wants $150 just to look at it. So i was hoping that there is an easy fix that someone may know. But you are right; I've better bring it in.
I talked to a friend yesterday who used to have a 328is. He said he had problems with his driver seat too. The last fix costed him over $800 because the whole frame had to be replaced.
ebotdm is offline
post #4 of 9 (permalink) Old 05-27-2004, 09:26 PM
kowached is an unknown quantity at this point
ebotdm, the seat memory (and steering wheel) positions are resident on the Drivers Seat Controller (61.31-6 910 717, $55). Most commonly the lower plastic trim piece on the drivers seat breaks at the outside rear, putting a strain on the wiring harness and eventually works the connector free, possibly shorting it out along the way.
Before you take it to the dealer, remove the lower trim piece on the seat and check the connector that is going to the seat controller that is mounted to the back of that trim piece (connector has a sliding lock). You may only need to re-seat the connector.
If you find a loose connector due to the rear trim piece mount that is broken, you can purchase a new trim piece (must buy drivers and passenger as one) that will break again, or simply zip tie the connector to the control box.
Later,
Dave
E39 - 1998 540iA Sport (11/97 Production)
E30 - 1989 M3 (44k miles)
1979 Triumph TR7, still have my first car ;-)
Past cars:
E21 - 1980 320i (sold at 130k)
E23 - 1986 735i
I am a BMW Car Club of America member, are you? <a href='
target='_blank'>
src='http://members.roadfly.com/kowached/bmwcca1.gif' border='0' alt='user posted image'>
kowached is offline
post #5 of 9 (permalink) Old 05-29-2004, 01:19 PM
02bmw540isilvergreynav is an unknown quantity at this point
yeah it is probably a loose wiring harness due to the fragile plastic seat trim peice. Mine broke the harness also on my 97 528i and I can just plug it in every once in a while if I need to move it. I am trading it in so I will not try to attempt to fix it.
02bmw540isilvergreynav is offline
post #6 of 9 (permalink) Old 06-01-2004, 09:52 PM Thread Starter
Kowached and 02bmw540i,
Thanks for the tip. That was exactly what it was, the trim piece being loosed. Heeding your advice, i took that piece of trim off and reseated all the connectors. To my delight, not only did all seat controllers work, but the memory part of it seemed to be working too.
The whole job took me less than 10 minutes. Compared that to the trouble of bringing the car into the dealer and paying whatever they wanted to charge for it, i was very happy. Thank you guys.
ebotdm is offline
post #7 of 9 (permalink) Old 06-01-2004, 10:25 PM
Slvr e39's Avatar
Slvr e39 has a reputation beyond repute Slvr e39 has a reputation beyond repute Slvr e39 has a reputation beyond repute Slvr e39 has a reputation beyond repute Slvr e39 has a reputation beyond repute Slvr e39 has a reputation beyond repute Slvr e39 has a reputation beyond repute Slvr e39 has a reputation beyond repute Slvr e39 has a reputation beyond repute Slvr e39 has a reputation beyond repute Slvr e39 has a reputation beyond repute
Send a message via AIM to Slvr e39
Same type of electrical problems have happened to my Moms 98 528i. She took it to BMW and they needed to change fuses and something else that I cannot exactly recall that cost about $1400...
Dinan Stg 2 Phoenix Yellow M3
Slvr e39 is offline
post #8 of 9 (permalink) Old 02-23-2011, 08:07 PM
Spike01 is on a distinguished road
You are brilliant! I had the same problem with my 540, so I removed the screw that holds the trim on the left side of the driver's seat and pulled the trim out, reset the connector (the sliding lock had disengaged) and VIOLA! It's fixed! Thanks very much!
Spike01 is offline
post #9 of 9 (permalink) Old 02-23-2011, 08:19 PM
Quoted: 1 Post(s)
Thread is from 2004, glad that worked though.
witeshark is offline
Closed Thread
E36 325i problem with power steering after doing doughnuts!?!? anar_325i 3-Series (E36) 10 10-12-2005 05:18 PM
power steering problem 1_bad_5 5-Series (E12,E28, E34, E39, E60) 3 09-24-2005 05:00 PM
Heated Seats lulul 3-Series (E36) 13 01-23-2005 06:18 PM
Problems with memory seat, 525I jam05 5-Series (E12,E28, E34, E39, E60) 1 09-25-2003 11:38 PM
