'97 528i no start after oil change - BMW Forum - BimmerWerkz.com
Old 12-20-2006, 06:44 PM   #1 (permalink)
jstbecauz is on a distinguished road
Today I put a new head on the 528i, got it finished up and took the car out to be run, and it ran great. So later on this afternoon ran it again then immediately changed the oil, but I didn't do it on a lift.
First I jacked up the right front, noticed that that was the side where the drain plug was so I let it down then jacked up the left front. I jacked up the car high enough where the rear tire was off of the ground when jacking from the front. Anywho, I changed the oil, filter let the car down and replaced the oil. Now the car will not crank. All the while the car was jacked up the key was in the off position, but is there any chance that having the car jacked up as I did caused it to set something in the antitheft where it will not crank any longer?
Any suggestions?
Thanks
jstbecauz is offline   Reply With Quote
Old 12-20-2006, 07:15 PM   #2 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
You could of accidently put the jack on the power cable from the battery to the engine causing it to come loose, it runs down the underside of the car. Problems like this are really hard to diag without seeing the car in person.
My M50 Powered E30 Page
oil change bow 1,6,7,8 - Series and Mini Cooper 2 12-11-2006 06:07 PM
Engine Oil: Dino vs Syn and AutoRx Larry Horne 3-Series (E36) 12 02-22-2006 01:38 PM
i want slightly thicker oil storme 3-Series (E46, E90) 42 01-10-2006 01:22 PM
timing belt change and mechanics in miami träumer 3-Series (E21, E30) 6 10-03-2005 03:44 PM
