97 528i nightmare!!!! - BMW Forum - BimmerWerkz.com
Old 12-11-2011, 10:16 AM   #1 (permalink)
9bmw7 is on a distinguished road
Hello everyone! I am sure hoping to get some good advice on my issues besides junk it or take it back... Now heres the story... I got this car from a guy who owed me some money and it was completely disassembled under the hood... I had to install the cylinder head intake, etc. I do not know what is missing, etc. I know the sensor next to the crank pulley is missing and the oil level sensor is not plugged in(cant find plug) and the o2s arent plugged in. Now the problem is the car will not turn over.. ive checked all fuses and they are good and if i read correctly it should.turn over with the oil level sensor unplugged... Anybody have any tips or areas to look?
9bmw7 is offline   Reply With Quote
Old 12-11-2011, 10:28 AM   #2 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
The Cam sensor is essential as are all the other sensors... These relay information to the ECU to establish its best running situation...
Eso es todo!
BMW Part Market
BMW Online Manuals (TIS)
New Member ?
Old 12-27-2011, 09:17 AM   #3 (permalink)
Penngwyne's Avatar
Car: E34 525i 1989/03
Penngwyne is on a distinguished road
BMW parts catalog
Try this link, put your VIN into it and check out the drawings and parts list
My daily is a Mitsubishi HSGR (but I wouldn't mind an e34 525i)
Penngwyne is offline   Reply With Quote
Old 12-27-2011, 11:22 AM   #4 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Yes it will run without oil sensors plugged in but you may get "Engine Warning" light (no panic)...
It will not run without the cam sensor as this relays TDC and signals via the VANOS solenoid to the ECU to create an optimum pulse from the ECU to fire the spark-plugs at the right time !!
Missing connectors? Hunt under the inlet manifold as they are usually hiding in this area...
I will stay with you on this because I have the exact same engine ;-)
HTH
Daz
Eso es todo!
BMW Part Market
New Member ?
Old 01-16-2012, 07:33 PM   #5 (permalink)
golfgod's Avatar
Car: 2001 540i and 1997 528i
golfgod is on a distinguished road
Send a message via Yahoo to golfgod
yes, it sounds like if it is the one next to your crank pully, then it would be the crank sensor...go to "oem .com" and save the link as a favorite...then put in the last 7 of your vin number and it will show you every part and sensor on your car and where it goes. oem.com is a great link and you can use the oem part number to get parts from external vendors to make sure you get the right one as they reference the oem part number
2001-540i
golfgod is offline   Reply With Quote
528i Sunroof Nightmare BruceC 5-Series (E12,E28, E34, E39, E60) 1 10-02-2004 10:37 AM
BMW Nightmare d_ketcham 3-Series (E36) 0 12-31-1969 07:00 PM
