97 528i Left Rear Door won't open!! - BMW Forum - BimmerWerkz.com
Old 04-21-2008, 08:25 PM   #1 (permalink)
ratfink is on a distinguished road
Angry 97 528i Left Rear Door won't open!!
After putting some things in the back seat we left the drive way and found the left rear door had not closed properly and was actually opening. I stopped and tried to shut it but it wouldn't latch. We went back home (one block) and tried cycling the keyless entry. This latched the door shut but now it won't open so I can't get the door panel off to investigate the problem. Both the inside and outside handles do nothing. I tried locking and unlocking while holding the handles open but don't really know what is wrong.
Any suggestions??
ratfink is offline   Reply With Quote
Old 06-19-2008, 11:26 AM   #2 (permalink)
p528I is on a distinguished road
got the same problem mate. Did you get this fixed? If so what was it? How much etc?
Cheers
p528I is offline   Reply With Quote
Old 06-19-2008, 11:50 AM   #3 (permalink)
Cheers
Old 06-19-2008, 09:18 PM   #4 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 95 525i
just a thought... disconnect battery a few hours ;-) reconnect and then let's see...
Old 06-19-2008, 09:20 PM   #5 (permalink)
Cool
you prolly scratching your head and wondering why?
the logic:
in order to figure this one out whether the prob is electronic or mechanical... and then you can proceed.
Old 07-01-2008, 05:58 AM   #6 (permalink)
I fixed it!
I finally got motivated and fixed the problem. First I took off the passenger door panel to see where the lock mechanism was and how it worked. Then I carefully pried back the rear end of the leather trim insert in the area of the lock mechanism on the driver side door panel. Next I cut through the hard shell material behind the leather panel and left a lip around the edge to maintain the shape. Now I have access to the lock mechanism from inside. As it turned out there are two different cables that go to the latch. One of these cables had gotten kinked over and held the mechanism in limbo (unable to lock or unlock). I popped it lose and put some good ole wd-40 on everthing for good measure. Once the door was open I took off the door panel the rest of the way and contact cemented everything back in place. Works like a charm and there is no visible damage to the door panel, and best of all it cost nothing but glue!
Door will not open from inside or outside...HELP!!! tylset 5-Series (E12,E28, E34, E39, E60) 20 03-28-2013 07:23 AM
E39 528i Rear Left Entrance Cover johnex Looking For 0 01-04-2008 09:52 AM
door wont open from outside nfbm 3-Series (E46, E90) 0 12-21-2007 05:56 AM
Door Won't Open From The Outside? lavalva 3-Series (E36) 10 04-05-2005 06:22 PM
My door won't open Eggrolled211 3-Series (E36) 5 12-03-2003 11:23 PM
