| if only one of the tabs is broken , you can use some silicone , i used permatex "the right stuff" because of its flexibility.
Jst put a small dab with a toothpick on the tab reciever set in position and let dry overnight.
It should work if both are broken , the stuff is very flexible .
might use a q-tip and clean off first with alcohol (rubbing)
