97 528 intermittent a/c - BMW Forum - BimmerWerkz.com
post #1 of 3 (permalink) Old 06-01-2013, 08:30 PM Thread Starter
So-Cal Steve is on a distinguished road
I have a 97 528. The car runs amazing. The only problem is that the a/c is intermittent. There are times when it is ice cold. It seems that when I need it the mos it only gets Luke-warm. Also there are times when the fan speed will not increase regardless of the fan setting. Am I looking at 2diferent problems? I have had the system completely evacuated and recharged with fresh freon by my general mechanic. There is no reason why it shouldn't be working. The clutch cycles fine. It is holding pressure...
I need some help, summer temps are already killing me.
So-Cal Steve is offline
post #2 of 3 (permalink) Old 06-02-2013, 05:26 PM
4DoorWhore
Lord Vader's Avatar
Quoted: 1 Post(s)
Welcome to Bimmerwerkz.
The fan speed is controled by the blower motor. If the fan is not increasing in speed when you select a higher setting then the motor, or the blower motor resistor may be failing. As for the lukewarm/cold issue, make sure your coolant level is topped up, and that all air is bleed from the system. An airbubble in the system can cause that. The coolant also feeds into the heater core.
And Follow Me on Instagram @E36M52
Founding Member of the Canyonrot Club! Paint Code #343
| OE M3 Bumper | M3 Mirrors | Max Velocity GTR Lip | Euro ZKW Projector Headlights | Jim Conforti CF CAI | UUC Motorwerks Underdrive Pulleys | 18x8 ASA AR1's | Koni Sport Springs & Shocks |
Lord Vader is offline
post #3 of 3 (permalink) Old 06-06-2013, 02:25 AM
Moderator
Dirty_Tool's Avatar
Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute
As Lord Vader said you may have a failing Final stage Resistor. Here is a link to a DIY: Replacing the final stage unit/blower motor resistor (E39) - Bimmerfest - BMW Forums
Also, for the lukewarm A.C. Does it happen when sitting at a stop but then cools down more while the vehicle is moving? Check to make sure that your auxillary cooling fan is running when the A.C is on. If the fan is not working then this can give you these symptoms. DIY: Aux Fan Replacement DIY - Bimmerfest - BMW Forums
Best of Luck,
DT
Dirty_Tool is offline
Intermittent AC OGF 3-Series (E46, E90) 0 08-20-2012 02:10 PM
Intermittent sound from RH speaker dimbim 5-Series (E12,E28, E34, E39, E60) 2 03-01-2010 10:22 AM
Intermittent Horn fowens 3-Series (E36) 1 01-22-2010 11:05 PM
535i With Intermittent Misfire V8-Schnitzer-UK 5-Series (E12,E28, E34, E39, E60) 11 05-16-2008 08:28 PM
Intermittent Prob 1985318i 3-Series (E21, E30) 2 10-26-2004 12:48 PM
