95 540i fuelfilter - BMW Forum - BimmerWerkz.com
Old 04-08-2004, 01:16 PM   #1 (permalink)
rileysdad is an unknown quantity at this point
I have the filter...looking for tips and tricks to install
rileysdad is offline   Reply With Quote
Old 04-08-2004, 03:20 PM   #2 (permalink)
Mach 5's Avatar
Mach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond repute
Depressurize the fuel system first. You pull the fuel pump fuse (or relay) and turn the car over to burn the gas in the line. This will keep you from spraying as much fuel everywhere. Have plenty of ventilation and make sure that the engine is cold as fuel splashed onto a hot manifold can cause a fire. Good luck
Ben
"It's not because I'm an aggressive driver, it's because I'm an idiot" actual quote from my wife.
Mach 5 is offline   Reply With Quote
Old 04-13-2004, 10:30 AM   #3 (permalink)
I need to do this also, how much fuel should i expect to lose?
After Market Clutch, flywheel and Short shifter for a 540i pamato 5-Series (E12,E28, E34, E39, E60) 1 10-19-2005 12:14 AM
e39 540i alternator and battery question HardStep 5-Series (E12,E28, E34, E39, E60) 5 10-11-2005 12:18 PM
Alpina E39 540i Obliterates Clk 430 Coupe! Delmarco Driving Tales 1 03-27-2005 09:44 AM
Vin Number skimmilk 5-Series (E12,E28, E34, E39, E60) 1 12-16-2004 05:07 PM
VIN CHECK wax Bimmer Talk/Motorsports Talk 3 07-11-2004 05:34 PM
