'95 525i 230k, lumpy acceleration&vibration - BMW Forum - BimmerWerkz.com
Old 10-20-2005, 10:32 AM   #1 (permalink)
raborg36 is an unknown quantity at this point
Exclamation '95 525i 230k, lumpy acceleration&vibration
Hello fellas, I have this anoying problem: when I'm either at idle or running through the gears, I feel a vibration in the engine. This occurs in time with the rpm's. I've elliminated the cooling fan and the other components on the face of the engine. I suspect either the crankshaft sensor or a faulty ignition coil.
The other issue is when I'm running through the gears, there is a : lumpy feeling, as if there is a restriction of some sort. This is my first Bimmer so I don't want to be discouraged from buying another when the time comes. <_< Plase assist if poss.
raborg36 is offline   Reply With Quote
Old 10-20-2005, 12:00 PM   #2 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
As far as vibration in the engine ... are you sure you just don't need new engine mounts ? They'll usually cause shaking/vibration once they go bad.
As far as the lumpy feeling, here is the whole troubleshooting chart from the Bentley manual. If you want the other stuff out of it such as how to read Check Engine Light codes etc, email me at straightsix@gmail.com.
Old 10-20-2005, 12:11 PM   #3 (permalink)
Are you 100% sure that the lumpy feeling and the vibration are related? I mean - the vibration could very well be drivetrain related. Maybe you should have a look into that as well as engine mounts like mentioned above, etc.
Otherwise, it oculd be as simple as a full tune up - or something like sticking injectors, vacuum leaks, etc.
If in the rare event this car had a more serious problem, I don't possibly see how you could be skeptical of buying another BMW in the future - You got 230k miles out of it, thats well past the typical life expectancy of any car on the road. Sure, we can all keep our cars running past 230k, but at some point you have to realize the car isn't what it used to be and it's not the car's fault. lol
Old 10-20-2005, 12:43 PM   #4 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
You didn't just say that about life expectancy of our cars, did you ?
Well not our cars ... our cars are like tanks -- They'll never stop running.
Old 10-21-2005, 12:16 AM   #5 (permalink)
Just because they last that long doesnt mean thats their life expectancy...
95 525i engine TDC w/VANOS yaofeng 5-Series (E12,E28, E34, E39, E60) 0 11-06-2005 05:39 PM
Used 525i rszanto 5-Series (E12,E28, E34, E39, E60) 2 09-06-2005 04:36 PM
525i And 530i Exterior Differences bmwnew 5-Series (E12,E28, E34, E39, E60) 2 01-20-2005 11:24 PM
E28 - Is The Radiator The Same On The 525i & 528i? roscoa1 5-Series (E12,E28, E34, E39, E60) 0 01-08-2005 02:28 PM
325i vs 525i Bengal94 3-Series (E46, E90) 2 10-25-2003 09:51 PM
