94 530 code 1213, MAF IAT Sensor? - BMW Forum - BimmerWerkz.com
Old 03-27-2009, 08:17 PM   #1 (permalink)
Car: 94 530i, 140 K mi, orient blau
lrayvick is on a distinguished road
Glad I found you guys.
I need an opinion about the intake air sensor. Bentley says the resistance across the terminals should be 2.5 K ohms at about 70 degrees F. I checked them all and got between .5 and 1.6. Anyone know how to test these?
I am in So Cal. Failed smog inspection by max limits on CO2, fine on CO and NOX. New OEM spark plugs. 140 K mi on motor with runs great, doesn't use oil, etc. Cat checks out ok and Bosch O2 sensors were new 20 K miles ago.
Found it was throwing code 1213 - Lambda Control 2 which means "fuel tank ran empty, Incorrect Fuel Pressure, Injector valve defective or coked, Engine Temperature Sensor defective, Secondary air leak, Fuel evaporation control system defective, Air Flow Meter defective and/or the combustion is being disturbed by mechanical failure (Spark plugs, compression, intake/exhaust valves, ...etc.)"
Fuel tank did not run empty. Fuel pressure is in spec.
lrayvick is offline   Reply With Quote
Old 03-28-2009, 03:23 PM   #2 (permalink)
Also I unplugged the sensor and started the car. It seemed to run a little rough and the check engine light came on. Plugged the sensor back in with the motor running and it died. Restarted it - as before.
Old 04-01-2009, 04:54 PM   #3 (permalink)
I was confused about the sensors - the IAT sensor tested good. Could not test the MAF sensor.
So I finally broke down and took it to a friend who has a BMW code reader. He confirmed that the MAF is bad.
Old 04-01-2009, 05:19 PM   #4 (permalink)
Sodium Chloride
saltshaker185's Avatar
Car: 95 M3
try some MAF cleaner before replacing the unit...
Iat Sensor?!!! thatfatguy 1,6,7,8 - Series and Mini Cooper 3 11-04-2009 05:06 AM
94 530i m60 e34 code 1213 car has a misfire help?? mybeamer 5-Series (E12,E28, E34, E39, E60) 3 03-04-2009 10:32 PM
Iat Sensor flemishlion 3-Series (E46, E90) 6 06-13-2005 11:59 AM
Iat Sensor smx 3-Series (E36) 4 03-11-2005 07:34 AM
IAT SENSOR! M5power 5-Series (E12,E28, E34, E39, E60) 4 03-28-2004 11:01 PM
