'94 525i trans program - BMW Forum - BimmerWerkz.com
post #1 of 9 (permalink) Old 01-08-2008, 10:22 AM Thread Starter
MalinT is on a distinguished road
Question '94 525i trans program
I've read a good number of "trans program" posts, but none are giving me the info I want. My wife is driving a family member's '94 525i wagon. This morning when she was leaving for work, she backed out of her parking place (no problem), put the car in drive and it wouldn't move (BIG PROBLEM!) The "trans program" indicator came on. She didn't know to try any of the lower gears, so she just reversed into another parking place.
So my question is how bad is this? From other posts I've gathered that there are a wide variety of problems that can cause the "trans program" indicator to come on. Could one of these lesser problems prevent the car from driving forward, or is our transmission shot?
If anyone knows of a reputable BMW service place in Birmingham, AL please let me know. I don't want to get screwed by our dealership. I still haven't quite recovered from paying $45 for some power steering fluid.
Thanks for any advice you guys can provide.
Malin
MalinT is offline
post #2 of 9 (permalink) Old 01-09-2008, 04:03 AM
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold
Yeah $45 for power steering fluid sucks...
I paid $90 for oil....but still OEM is the best.....
Hopefully somone can point you to a specialist in your area
BUT How many miles are on the car?
Try putting is into the lower gear's.
Sadly your trans could be gone....
How many miles since last fluid change?....
Could be the valve body is sticky......
Also when it is in the low gear try verying the RPM's it might pop in gear.......
Buddys 535i did that.... It did pop into gear....
But the trans needed to be replaced shortly later because or slippage.... have you noticed any slippage?
1992 318i Coupe parts car
I am Captain Obvious
AlpineSixAndSeven is offline
post #3 of 9 (permalink) Old 01-09-2008, 10:49 AM Thread Starter
Interesting development
When I got home last night, I started up the car to check out the lower gears, and the car drove just fine in all gears. The "trans prog" indicator didn't even come on. What is that all about?
Anyway, in answer to your question, the car has about 215,000 miles on it. I haven't noticed any slippage in the transmission, but I don't drive the car nearly as much as my wife does. Since it is borrowed, we don't know when the fluid was last changed. Thanks for the input though.
If anyone can explain the sudden change in the transmission working I would appreciate it.
Thanks!
MalinT is offline
post #4 of 9 (permalink) Old 01-09-2008, 06:34 PM
yeah... the valve body is probably sticking.... i sugest a fluid and filter change.....
post #5 of 9 (permalink) Old 01-10-2008, 10:42 PM
at 215,000 miles, it could be anything.
Has anything been spilled in the gear selector? A lot of times, that may cause the problem.
sp0rky is offline
post #6 of 9 (permalink) Old 01-17-2008, 04:50 PM
d3ity will become famous soon enough d3ity will become famous soon enough
Relax man, it's not really that bad. Trans program is a computer error, not a huge transmission problem. Your trans is most likley fine, but it's not properly communicating with the computer. Just like most bmw problems, the part did not break, but the sensor that monitors the part did.
Alpine, the valve body is definatley not causing a trans program message. Trans program occours when the transmission computer runs into an error, faulty ground, shorted connection. What the car does when trans program appears is lock itself in 3rd gear. you can drive it.... but you've got 3rd gear to start and end with. It won't shift.
as someone who has battled trans program before...
There are MANY things that cause this. Your dealer will want to replace the transmission and trans computer. Don't.
Check here: BMW E34 Website
I noticed that on my vehicle, the 1993 525i (my dad's), the problem seemed to come and go with temperature. I suspect a faulty ground and I never really got to the bottom of the problem. All I know is following those troubleshooting steps took the problem from constant whenever there was cold weather, to very very seldom. By seldom I mean maybe once every 3 months I start the car and it does it, however, shutting it off and turning it back on fixes the problem.
<iframe src="http://gamercard.xbox.com/TiddlyPlatypus.card" scrolling="no" frameBorder="0" height="140" width="204">Put your gamertag here too.</iframe>
d3ity is offline
post #7 of 9 (permalink) Old 01-17-2008, 11:17 PM
^Then why woulnd the car move? my friend 535i Did it. trans program thing came on didn't have any gears but reverse.... then again it was turbo'ed...
post #8 of 9 (permalink) Old 01-21-2008, 08:57 PM
Transprogram is NOT just a computer error.
Its a failsafe program designed to keep the transmission from causing itself even more damage.
It's POSSIBLE that its related to a computer issue, but its even more likely that its a hardware issue. Transprogram is mostly set off when a transmission slip is detected - meaning the clutches are at the end of their service life.
sp0rky is offline
post #9 of 9 (permalink) Old 01-21-2008, 09:41 PM
^ thats what i thought......... i just was going of preveous expereance with a 535i turbo.... and he killed the clutches....
Trans Program camper1159 5-Series (E12,E28, E34, E39, E60) 1 04-10-2009 09:38 PM
my trans program light came on in my 750 geo7inbodydrop 1,6,7,8 - Series and Mini Cooper 1 05-26-2007 10:26 AM
Trans program Hoopty 5-Series (E12,E28, E34, E39, E60) 7 01-04-2004 04:25 AM
