'93 E34 heating issues - BMW Forum - BimmerWerkz.com
post #1 of 9 (permalink) Old 11-01-2010, 02:05 PM Thread Starter
Rupesy's Avatar
Rupesy is on a distinguished road
New to this forum....hello everyone....
My car has been off the road for a little while and I just got everything straightened out (head replacement). Also has 240k. It was 32F this morning and I noticed my heater was not pumping out the hot air like it normally used to. It was more warm than anything else. I thought maybe I still have an air bubble since I just filled the radiator, but the radiator is bled and full. I noticed a few other issues as well. Here are the symptoms:
(1) The top dashboard vent only blows cold air
(2) Only a little air volume (hot) comes out the defrost, when only the defrost is selected....but I can hear the blower motor running full blast
(3) Only a little air volume (hot) comes out the floor heat, when only the floor heat is selected...but I can hear the blower on full blast
(4) When all three are selected (defrost, floor and vent), only a little air comes out the vent and it is cool
(5) When only the vent is selected, it has high air volume and it is mostly hot, but not as hot as it should be....
***blower seems to be working fine
other issues maybe related
(1) when a/c is selected, sometimes the a/c turns off (lights go out)....I have been able to get it to come back on by wiggling the fan speed dial and moving the dial in and out a little so I think it may be the contacts in the dial
(2) on occasion, the blower may stop working at fan position 2 or 3 (can't remember which)....turning it off and on again usually corrects the issue.
I think these two may be that I just need to replace the controls, but just thought I would add that in.
I did do some searching first, but didn't find exactly what I was looking for. I am a little confused between the blade, control module, and some of the other servos that control different things. Hopefully some of my description will help narrow it down.
Rupesy is offline
post #2 of 9 (permalink) Old 11-02-2010, 05:23 PM Thread Starter
Rupesy's Avatar
update.....
After reviewing some diagrams, I am convinced at least one issue is related to the dial between the middle dash vents. It is supposed to let in fresh air on the blue dot and switch over to hot with the red dot. Nothing changes when I move it up and down and it feels loose. Going to check to see if the cable broke.
Also, if I switch on the recirculate button, I can hear a flap move and then the air in the middle vent gets really hot (which was previously warm). More air comes out the defrost vent when it is selected by itself and more air comes out the floor when it is selected by itself.
I think for now I am going to work on the dial between the vents......
Rupesy is offline
post #3 of 9 (permalink) Old 11-08-2010, 03:35 PM
Rogier is on a distinguished road
had the same problem and changed the watervalve, the part that lets coolant circulate into the driver/passenger compartment. it didn't work properly
don't know if its the same problem but i had some of the same symptoms
RealOEM.com BMW E34 525i Water valve/Water hose
number 15
Rogier is offline
post #4 of 9 (permalink) Old 11-09-2010, 04:16 PM Thread Starter
Rupesy's Avatar
Thanks for the post. I meant to post back with pics on what I found. I tore the middle dash vent apart and traced a wire to a servo located on the passenger side footwell. Took the trim off and found the servo had broken off. It is the servo for fresh air so the flap was stuck in the middle which is why I was getting lukewarm and cold air. When I attempted to put the servo back the servo was in the wrong position, so I had to remove the servo from the gearbox and line it back up to the flap. Only problem was that the servo would not stay in place due to some broken plastic. I found a place to put a long screw through the gearbox and mounted it firmly. Everything is working as it should now an the hot air is now toasty. I will post some pics later tonight.
'93 BMW 525 240k
'93 Suburban 100k
'93 Chevy Astro 250k
'79 Porsche 928 85k
'00 Ford F250 V10 135k
'95 Ford F150 4X4
'77 Fiat Spider
Rupesy is offline
post #5 of 9 (permalink) Old 11-09-2010, 07:02 PM Thread Starter
Rupesy's Avatar
Here are a few pics
ID:	29540   Click image for larger version
ID:	29541   Click image for larger version
ID:	29542   Click image for larger version
ID:	29543   Click image for larger version
'93 BMW 525 240k
'93 Suburban 100k
'79 Porsche 928 85k
'95 Ford F150 4X4
'77 Fiat Spider
Rupesy is offline
post #6 of 9 (permalink) Old 10-13-2012, 06:55 PM
jaysettle is on a distinguished road
Rupesy thanks for your post, it helps a bit. I just bought a 94 e34 with 97,000 miles, and am having a similar problem however I don't get any hot air from all vents circled in red. I do get heat from the floor and defrost but not very fast moving heat at all. I'm new to this car and this forum and really wondering:
1. how does the stock heat work in these cars...am i supposed to get heat from all vents?
2. if I fix the servo, assuming this will get me only heat out of the 2 center sidebyside vents, what can I do about the top center vent and the side vents blowing only cold?
3. did you ever figure out how to get a higher flow of heat from the defrost and floor, i'm having the same issues there too and its about get very cold.
https://www.dropbox.com/s/tsyg4tyw621h4iu/photo.JPG
jaysettle is offline
post #7 of 9 (permalink) Old 10-22-2012, 11:07 PM
fixed heat problem in e34 1994 530i
Ended up finding the same problem as Rupesy and fixing it just how Rupesy did. thanks!
post #8 of 9 (permalink) Old 11-11-2012, 05:19 PM Thread Starter
Rupesy's Avatar
Glad that post was of some use! Sorry I did not get back to your original questions. I had the same motivation to fix mine back when I originally posted....it was getting cold!
I never really got much farther than the fix I did, however, I believe I still had some small issues. I didn't mess with it any further and put investigation of the rest off for another rainy day project. I figured that at some point I would need to look at each servo individually.
'93 BMW 525 240k
'93 Suburban 100k
'79 Porsche 928 85k
'95 Ford F150 4X4
'77 Fiat Spider
Rupesy is offline
post #9 of 9 (permalink) Old 06-28-2014, 06:15 PM
Thomase is on a distinguished road
Question
Hi Rupesy I note your post is about 4 years old but I am hoping you or some other member can assist me with the same fault as in your case.
1993 520i E34 M50, When attempting to change cabin filter (RHD,split filter, because of steering column PITA) noticed a stepper motor and gearbox hanging on wire harness as you described. do you have to take the center console and dashboard covers of to gain access ? if so is there a link to this procedure?
Thomase is offline
e34 over heating problems e34fan 5-Series (E12,E28, E34, E39, E60) 5 05-30-2009 11:35 PM
over heating latreal 1,6,7,8 - Series and Mini Cooper 2 01-26-2009 01:08 PM
e34 tds starting issues (with pic) abz2005 5-Series (E12,E28, E34, E39, E60) 2 01-12-2009 03:23 PM
heating issues pooskay 3-Series (E36) 18 11-12-2004 06:02 PM
heating steveinwa 3-Series (E36) 3 10-25-2003 06:57 PM
