92 E34 wont crank - BMW Forum - BimmerWerkz.com
post #1 of 3 (permalink) Old 08-19-2007, 02:59 AM Thread Starter
92beemer535 is on a distinguished road
Unhappy 92 E34 wont crank
I've got a 1992 535i with an e34. Recently it overheated and blew the expansion tank hose. i replaced the hose and troubleshot it to the fan clutch but havent had a chance to replace the clutch yet. Havent overheated since i replaced the hose so it has been running fine. Yesterday i ran the car all day with no problems and parked it in my driveway with the windows down. i tried to start it this morning and nothing. everything turns on but it doesnt crank, it doesnt even attempt to start, nothing at all. Please help what do i do?
92beemer535 is offline
post #2 of 3 (permalink) Old 08-19-2007, 05:03 PM
Millions of them.
Torque's Avatar
Quoted: 1 Post(s)
Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute
What do you mean by "everything turns on"? All the lamps etc? I'd check the battery first still, then if that's good, check the relays for the starter etc ...
Oh btw, if it's a manual, push start it ... should work if the battery has any juice at all.
Torque is offline
post #3 of 3 (permalink) Old 08-25-2007, 01:09 PM
d3ity will become famous soon enough d3ity will become famous soon enough
Pull your spark plugs and see if they smell like gas. If you smell gas on them you're probably flooded. If you moved the car say about 5-10 feed and then just shut it off it's a possibility.
Worst case you have a jammed injector. Throw some injector cleaner in it and attempt to raise the motor's compression. Check the codes before you do this.
Get yourself a quart of oil and a turkey baster, pull all the plugs, and drop some oil down the spark plug holes. Put your plugs back in and try to start it. You will have an assload of smoke from the burning oil, but if the car is flooded it should give it enough compression to turn it over and get it running on it's own. Make sure you drive it until it stops smoking to get all that oil out. It may try and stall on you, so keep an eye on the tach.
d3ity is offline
E28, E34 in snow BlueSteel 5-Series (E12,E28, E34, E39, E60) 10 03-30-2009 05:31 PM
e34 previous owner e36 new owner PScalfano New Members Check In 2 04-23-2007 11:20 AM
Can I swap my e34 3.0L v8 with a e34 4.0L v8 & tarnny? bimerguyCW 5-Series (E12,E28, E34, E39, E60) 4 01-09-2007 06:24 PM
e34 1989 525i m20b25 not charging Kyytsis 5-Series (E12,E28, E34, E39, E60) 5 04-08-2006 07:20 AM
Question regarding E34 front carpets m3driver97 5-Series (E12,E28, E34, E39, E60) 0 10-13-2005 02:32 PM
