'89 525i Gauges - BMW Forum - BimmerWerkz.com
Old 09-21-2004, 09:44 PM   #1 (permalink)
hrdrsrman is an unknown quantity at this point
tach completely stops working,fuel and temp drop to about 1/2 the original working reading. this happens randomly for no appearant reason. ocassionally this corrects itself upon restarting but not always. any help? thanks.
hrdrsrman is offline   Reply With Quote
Old 09-22-2004, 08:45 AM   #2 (permalink)
njtech is an unknown quantity at this point
Pull the cluster and check the connectors for corrosion or oxidation. Make sure the pins are tight, spray contact cleaner on the connectors. I use the cleaner from Wurth, but i heard that Radio Shack makes a good one. If this doesn't do the trick, probably the cluster itself( can be rebuilt if needed) HTH
Steve
njtech is offline   Reply With Quote
95 525i engine TDC w/VANOS yaofeng 5-Series (E12,E28, E34, E39, E60) 0 11-06-2005 05:39 PM
External Gauges Aznhiga 3-Series (E21, E30) 4 05-29-2005 02:56 AM
E28 - Is The Radiator The Same On The 525i & 528i? roscoa1 5-Series (E12,E28, E34, E39, E60) 0 01-08-2005 02:28 PM
Side Moldings ('89 525i) ruffrydasean 5-Series (E12,E28, E34, E39, E60) 0 11-28-2003 05:08 AM
325i vs 525i Bengal94 3-Series (E46, E90) 2 10-25-2003 09:51 PM
