Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 08-27-2008, 01:21 AM   #1 (permalink)
Photos: 0
Hypnotised is on a distinguished road
'87 535i Clutch Problem
Starting about a month or so ago, when I would go to my '87 535i after it sat all night, the clutch would have slipped down about halfway overnight. Hydraulic? All I had to do was put my foot behind it and pull it back up, and it was back in place and fine. Now it's gotten to the point where while I'm driving around town, about every 15th or 20th time I push the clutch in, it will not come back up all the way. However, if I put my foot behind the pedal and pull it back up, it stays in place. Now something is obviously wrong, but I'm just not exactly sure what to replace. I've been told several different things. I've been told it's probably the clutch disc and the pressure plate. I've also been told it's probably just the clutch slave cylinder. I've priced the entire clutch kit (cheapest brand OEM $274.00. It may be a LuK. Also an AutoCom brand for $221.00.), and a slave cylinder for about $50.00.
I am not a wealthy man, so do you think it may be possible to just replace a few select parts (i.e. clutch kit and pressure plate) only, and not have to do the clutch master cylinder, also? I have a mechanic who will do all the labor for about $300.00. GREAT DEAL! It still comes out to be around $600.00 total, no matter how you look at it.
Based on what I have described it is doing, what do you all think might be the crux of the problem here.
Thank you.
Tom B.
Hypnotised is offline   Reply With Quote
Old 09-03-2008, 07:43 PM   #2 (permalink)
Photos: 0
Hey. I posted this on Aug 26 and still have no reply. Anyone with some clutch expertise out there?
Old 09-15-2008, 10:25 PM   #3 (permalink)
Photos: 0
pulafets is on a distinguished road
just change it
if ur going to keep it for a long time just change it, that price is half of what bmw charges
pulafets is offline   Reply With Quote
Old 09-16-2008, 12:50 AM   #4 (permalink)
Teh whore
AlpineSixAndSeven's Avatar
Car: 1986 325es, 1987 635CSi, 1976 Benz
Photos: 0
^ please know your information and what your talking about BEFORE advising people on what to do.... Specially on such a big job such as a clutch.... Thanks
Around $220 isn't bad for a clutch... But you don't need one from your description
It sounds like you need to replace The Clutch Slave Cylinder and Clutch Master Cylinder Replace the line too because it is probably going to go soon to! It Sounds VERY much like your hydrolic fluid is eather leaking out of the slave Cylinder or leaking passed the seal in the Clutch Master Cylinder up to the resevoir or out into the cabin(by you pedals)
Originally Posted by Hypnotised View Post
.........I am not a wealthy man, so do you think it may be possible to just replace a few select parts.........
Ok, I just read it again Change your Clutch Master Cylinder(Not to be confused with the brake!) Then the slave Cylinder
Check is the slave cylinder is leaking ALSO BEFORE ANYTHING Check your brake fluid level is it low?(Clutch uses the same resevior) does it keep going down? if so see where it is leaking out (check by the clutch pedal) and under the car If it isn't leaking in the car(Check CAREFULLY for dampness and check behind the carpet!) then change the Slave cylinder first!
Originally Posted by drz View Post
I'll never be bound to no man by means of a piece of paper
Originally Posted by My Auto Trans Teacher View Post
Butt plugs saved my life
Old 09-16-2008, 11:18 AM   #5 (permalink)
marti5's Avatar
Car: E38 1997 735i
Photos: 0
I agree with Alpinesixandseven, thats if you want a second opinion.
vB code is On
Problem With Speedo On 1991 E34 535i ben_t 5-Series (E12,E28, E34, E39, E60) 0 12-29-2004 02:51 AM
Is This A Clutch Problem? frank3 3-Series (E36) 17 11-25-2004 04:04 PM
Maybe a clutch problem? Boost 3-Series (E36) 2 06-12-2004 06:01 AM
a possible clutch problem? Furious 3-Series (E36) 6 12-20-2003 03:37 AM
another clutch problem Furious 3-Series (E36) 6 11-23-2003 10:26 AM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
