Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 11-25-2005, 10:21 AM   #1 (permalink)
Photos: 0
andy81563 is on a distinguished road
'82 528e No Start
Here we go again...another "no start" problem with an e28.
Car died while driving down interstate; no forewarning, no prior symptoms. Had it towed back home, will turn over, but no start.
I replaced fuel pump and main relays, no start.
I replaced fule pump, no start.
I checked ignition, no spark therefore no start.
Speed and reference sensors are fine (read OK per Bentley manual).
Coil readings are fine; rotor, cap and coil wire are fine.
What else is there, except a faulty Motronic ecu, or reference pin on flywheel?
If it is the ecu, does anyone have one they would sell?
Andy
'82 528e, '92 325i, '99 540i/6
andy81563 is offline   Reply With Quote
Old 12-10-2005, 09:59 AM   #2 (permalink)
Photos: 0
arkhaus is an unknown quantity at this point
My 87 did this to me with the same symptoms -- all the sensors checked ok, plenty of fuel etc but no spark. It was caused because the raised pin on the flywheel that the reference sensor reads had broken off. We tried to weld it back on but couldn't and ended up replacing the flywheel.
Mike
'87 528e 380,000+ miles and going
arkhaus is offline   Reply With Quote
vB code is On
323i Wouldn't Start TRuckee 3-Series (E46, E90) 8 12-04-2005 02:41 PM
Car Won't Start - Help - Fuel Pump Relay? e36is 3-Series (E36) 24 09-08-2005 06:51 PM
Run Out Of Gas Wound Start (help) p_villa3030 6,7,8,X,Z - Series and Mini Cooper 0 04-08-2005 12:48 AM
'93 325i Won't Start 86VFR750R 3-Series (E36) 3 12-05-2004 09:32 AM
Cold Start Problem (fuel Pressure Drop) BEX 3-Series (E36) 6 05-16-2004 08:35 PM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
