BMW Forum - BimmerWerkz.com
BMW Forum - BimmerWerkz.com (http://www.bimmerwerkz.com/forum/)
-   5-Series (E12,E28, E34, E39, E60) (http://www.bimmerwerkz.com/forum/5-series-e12-e28-e34-e39/)
-   -   1989 535i running rough (http://www.bimmerwerkz.com/forum/5-series-e12-e28-e34-e39/1989-535i-running-rough-76545.html)
zabe 1 08-27-2012 02:23 AM
Help ?? 1989 535i
Problem. when started idles for a few seconds,then starts running rough.put foot on accelerator doent seem to have any power. missing running rough smell of rich fuel from Exhaust.Any advise appreciated Thanks
ZenitramNaes 11-09-2012 07:11 PM
Bump. Have the same problem with my 89 535i.
OP, did you fix the problem?
Sent from my iPhone using Autoguide.com App
jkozell 05-21-2013 06:26 PM
Originally Posted by zabe 1 (Post 650268)
Help ?? 1989 535i
Turn key to on, Floor accelerator 5 times within 5 seconds, count the "check engine" light flashes. It will flash out the code that the on-board computer has in it, and possibly the problem. With my 535i - Mass airflow sensor. You'll have to search and look up the meaning of the codes. For example: 1 flash, short pause, 4 flashes, short pause, 3 flashes, short pause, 1 flash, LONG pause would be trouble code; 1431 (not an actual code, by the way...) Good luck ;)
Synesthesia 07-16-2013 06:07 PM
Changed spark plugs recently? Check valve adjustments?
M30 engines are awesome. My mechanic told me it's bullet-proof. I believe it.
Good luck, it seems like an easy fix. Be friends with an independent BMW mechanic in
your area.
Bois 08-05-2013 05:13 PM
how long has it been since the spark plug wires were changed? Old wires will produce a lot of strange behavior on that motor.
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
