76' 530i - BMW Forum - BimmerWerkz.com
post #1 of 7 (permalink) Old 04-28-2003, 01:45 PM
Ben Wiseman
Guest
Posts: n/a
Quoted: Post(s)
Thumbs up
i own a 1976 BMW 530i and i drove it for about a year and all of a sudden the car will not go over 2500 rpms ....the engine starts and idles fine and runs fine up til the 2500 rpms then it cuts out and backfires....i was thinking it was either an air intake problem....or a fuel problem....any help in figuring out why my bimmer is broke will be appreciated...
thanks.
-ben
post #2 of 7 (permalink) Old 04-29-2003, 03:34 PM
cam540 is an unknown quantity at this point
**bump
any mechanics??
<img src='http://people.albion.edu/dbc10/images/w04.gif' border='0' alt='user posted image' />
<a href='http://
target='_blank'>Real Estate Books</a> | <a href='
target='_blank'>Spotya! Quick Cash</a> - Short term cash loans for online shopping.
<a href='
target='_blank'>Real Estate License</a> | <a href='https://
target='_blank'>My LinkedIn Profile</a> - Contact me
cam540 is offline
post #3 of 7 (permalink) Old 04-29-2003, 09:19 PM
Fox
Moderator
Ok.. there are a couple things that i can think of. First, about not going over 2500 RPMs. This sounds like either bad ignition and/or bad fuel delivery, change your spark plugs and get your carbs cleaned (this could be many many other things but Im just puttign the simplist possiblilties). But then you mention that once it gets to 2500rpms it backfires and cuts out (does the engine stall at this point or just drop RPMs?) The backfireing i would think is a improper ignition timeing OR maybe your catalytic converter is full. If it is absolutely full it may create enough backpressure to stall and backfire the engine at 2500 rpms but below that engine speed not enough pressure is created. If your cat is full then it will smell like rotten eggs usually. However about the ignition timing, if it is a conventional distributer with points (not an electric distributer) this is a high possibility. The points will wear down and must be filed and re-spaced.
Fox is offline
post #4 of 7 (permalink) Old 04-30-2003, 07:15 AM
Fox
Moderator
hump on the bump.
Fox is offline
post #5 of 7 (permalink) Old 04-30-2003, 03:48 PM
Guest
Guest
Posts: n/a
Quoted: Post(s)
thanks for the ideas.....when the engine hits 2500 rpms it drops rpms....it doesnt stall...
ill try checking some of those possiblilities...
thanks again
-ben
post #6 of 7 (permalink) Old 05-03-2003, 06:42 AM
Retired administrator
triggrhaapi's Avatar
triggrhaapi has a reputation beyond repute triggrhaapi has a reputation beyond repute triggrhaapi has a reputation beyond repute triggrhaapi has a reputation beyond repute triggrhaapi has a reputation beyond repute triggrhaapi has a reputation beyond repute triggrhaapi has a reputation beyond repute triggrhaapi has a reputation beyond repute triggrhaapi has a reputation beyond repute triggrhaapi has a reputation beyond repute triggrhaapi has a reputation beyond repute
there are alot of possible causes
burnt valves/stuck valves/broken valvespring (is there a ticking noise?)
ignition timing like fox said
bad carb or burnt fuel injector
failing fuel pump
in such an old engine, the possibilities are endless. I'd take it in to a shop and get a cylinder compression check and get the ignition, fuel and valve systems looked at.
Addicted to Speed Since 1997
triggrhaapi is offline
post #7 of 7 (permalink) Old 05-11-2003, 08:24 PM
e36_m3_Turbo's Avatar
e36_m3_Turbo has a reputation beyond repute e36_m3_Turbo has a reputation beyond repute e36_m3_Turbo has a reputation beyond repute e36_m3_Turbo has a reputation beyond repute e36_m3_Turbo has a reputation beyond repute e36_m3_Turbo has a reputation beyond repute e36_m3_Turbo has a reputation beyond repute e36_m3_Turbo has a reputation beyond repute e36_m3_Turbo has a reputation beyond repute e36_m3_Turbo has a reputation beyond repute e36_m3_Turbo has a reputation beyond repute
i heard shell has shitty gas and makes the fuel pump all slushy and makes fuel deliever bad
No longer red.
e36_m3_Turbo is offline
Custom 530i Or M3? Rugged530i 5-Series (E12,E28, E34, E39, E60) 2 01-15-2005 07:45 PM
High Price on Used 530i? BookemDano 5-Series (E12,E28, E34, E39, E60) 4 07-21-2004 12:34 PM
FS: 2001 E39 530i - PERFECT CONDITION JCz04Bimmer Classifieds Sell & Buy 1 07-03-2004 11:47 AM
2002 530i w/ angel eyes crayzehpnoy85 5-Series (E12,E28, E34, E39, E60) 0 03-30-2004 12:53 PM
