Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 11-30-2004, 11:05 PM   #1 (permalink)
///Matt's Avatar
Photos: 0
Send a message via AIM to ///Matt
Just started up my 97 540ia...weather is mid 30's flurries and rain....the check engine light starts to flash. I checked the codes with my reader and it gives me the following...
P0300 Random/Multiple Cylinder Misfire Detected ghead
P0301 Cylinder 1 Misfire Detected ghead
P0302 Cylinder 2 Misfire Detected ghead
P0303 Cylinder 3 Misfire Detected ghead
P0305 Cylinder 5 Misfire Detected ghead
P0306 Cylinder 6 Misfire Detected ghead
P0307 Cylinder 7 Misfire Detected ghead
Codes P1174 & P1175 also were detected but apparently this is the default for any kind of error.
Question: What do i do now?
BTW - I would reccomend to anyone the "Actron" code reader availiable at autozone for only $80!...It comes with a book and cd of codes
1997 540i - 200,000 Miles Strong
1988 325ic - Still at 16,000 Miles
1987 635csi L6 - In Restoration(To be completed April 2007)
///MATT
Old 12-01-2004, 12:01 AM   #2 (permalink)
Moderator
Dirty_Tool's Avatar
Photos: 0
Have you checked for vacuum leaks yet?
what about the cats have you checked for plugged cats?
DT
http://dtbmw.com/dt540
Old 12-01-2004, 12:42 AM   #3 (permalink)
billB's Avatar
Photos: 0
How can the cats be tested when plugged?
DT: I was told the old way used to drill a small hole before the cats and hoped to get 2-3 pounds for normal readings. Is this still true? Is there a more civilized way to check? thanks
Old 12-01-2004, 08:35 AM   #4 (permalink)
Photos: 0
njtech is an unknown quantity at this point
the converters can be checked using a backpressure guage. it mounts in place of the pre-cat o2 sensor, you bring the rpms up to 2500, anything more than 1.5 psi indicates a plugged converter.
as far as the multiple misfire codes I would check,
1) the spark plug connectors, make sure they aren't sitting in an oil bath.
2) the pcv plate in the back of the intake.
3) the manifold gaskets for vacuum leaks.
HTH.
Steve
njtech is offline   Reply With Quote
Old 12-01-2004, 11:32 AM   #5 (permalink)
Photos: 0
rsn48 is an unknown quantity at this point
Take it to your closest dealer for a service check.
rsn48 is offline   Reply With Quote
Old 12-01-2004, 11:42 AM   #6 (permalink)
///Matt's Avatar
Photos: 0
[snapback]241244[/snapback]
I figured that....however I just had "Inspection II" about a month and a half ago...What's another $700 anyway?
///MATT
Old 12-01-2004, 11:45 AM   #7 (permalink)
Photos: 0
Shouldn't be $700 for "timing" issue, though I know it is now electronic timing. In fact, they will have their results in your filel, I'd ask to see it, then go from there.
Old 12-02-2004, 02:50 AM   #8 (permalink)
Moderator
Dirty_Tool's Avatar
Photos: 0
bckpressure is a good test for the cats but also most of the BMW cats will break apart inside and you can hear them rattle when tapping on them with a rubber mallet. this is a faster easier but of course less accurate test. but suprisingly I catch most of the by just doing a simple "hammer test"...LOL
DT
DT
vB code is On
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
