540i shakes badly and left front wheel HOT - BMW Forum - BimmerWerkz.com
Old 03-20-2010, 05:18 PM   #1 (permalink)
wayned is on a distinguished road
My '99 BMW 540i started shaking over 40 MPH quite badly. It is intermittmentnet however, is becoming more violent where the entire car shakes badly for a while. It settle down and returns. Also noticed my left front wheel is very hot whereas the other three are cool. Just had my brakes done but that was 6 months ago and doesn't appear to be related as the shaking on started this week. Since the shaking started I changed my wheels/tires back to summer however, this hasn't stopped the shaking. Does anyone have any ideas?
1999 BMW 540i 6 spd
wayned is offline   Reply With Quote
Old 03-20-2010, 06:00 PM   #2 (permalink)
42, The meaning of life
brettski's Avatar
Car: 2000 740iL Individual
If you jack the front up and try spinning the wheel in question. the front ones should spin easily (relatively speaking) and fairly quietly, if there is a big difference in the amount of force or noise (a rumble or crunching noise is bad) then its likely to be a wheel bearing issue, if it just locked or really restricted in its movement, it could be that the brake caliper is stuck out and holding the pad on the disc. Good luck.
Old 03-21-2010, 01:50 AM   #3 (permalink)
german-speed-demon's Avatar
bad caliper or bearing. either way fix NOW as it could fail in a manner you would not prefer, trust me. As in, the wheel could fall OFF while driving.
R.I.P fast 6
Old 03-21-2010, 07:54 AM   #4 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
I would say deffo a sticky caliper..
Old 03-21-2010, 11:13 PM   #5 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 95 525i
Two issues are apparent:
1) shaking at certain speeds point to defective wheel balancing or a tire "out-of-round" so to speak. I suggest you have your front wheels checked out for trueness and dynamically balanced... and perhaps wheel alignment.
2) one tire abnormally hot tells you that the brake caliper is defective as mentioned earlier.
Good Luck.
Old 03-22-2010, 01:18 PM   #6 (permalink)
You were correct the caliper had seized. Replaced and all working perfectly. Thanks for you input.
1999 BMW 540i 6 spd
Old 03-23-2010, 07:48 AM   #7 (permalink)
brettski's Avatar
Well done. Glad it was a simple fix.
Terrible noise from rear left wheel. Magice 3-Series (E36) 5 02-21-2009 11:04 AM
lost sound on left speakers (front and back) sj_525nut 5-Series (E12,E28, E34, E39, E60) 4 02-26-2006 08:52 AM
Slight Vibration (Left/Front Wheel) Bunny Capricorn 5-Series (E12,E28, E34, E39, E60) 5 12-19-2005 08:24 AM
Dealership Wants $450 For Abs Left Wheel Sensor!!! Delmarco 3-Series (E36) 10 07-16-2005 04:35 PM
Front Left Fender Andnose Panel moe_j 3-Series (E36) 1 04-24-2005 10:49 AM
