Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 07-01-2008, 01:43 AM   #1 (permalink)
Photos: 0
yrshaik is on a distinguished road
540i intermittant no starter response
Greetings. I have an intermittant fault on my '98 540 where I get no response from the starter when the key is turned. All ign lights ok. I find that when this fault occurrs it sometimes helps if I key in the code to disable the car and enable again. A relay can be heard behind the cluster and the car starts. Could this relay be the cause and where is it located? Help.
By the way, I finally got the car phone working.
yrshaik is offline   Reply With Quote
Old 07-01-2008, 05:34 PM   #2 (permalink)
Photos: 0
Seems immobilizer is active as I forced starter to turn but engine does not fire up. Also, fault occurs more often now and also "brake light" warning displayed intermittantly even though bulbs replaced. HELP
Old 07-01-2008, 08:09 PM   #3 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 99 C43 AMG, 89 300SEL
Photos: 0
Send a message via Yahoo to darkhorse737 Send a message via Skype™ to darkhorse737
you said:
1) "...I get no response from the starter when the key is turned."
and you also said:
2) "...I forced starter to turn but engine does not fire up"
which is which... both???
ay sino caddi ububblaem? Heaven won't take me; and Hell just knows I'll take over...!
Old 07-02-2008, 01:56 AM   #4 (permalink)
Photos: 0
Thanks 4 responding. Turning the key in the ign produces no response from the starter even though all dash lights ok. Checked battery - ok.
While in this condition, I shorted out starter relay (in white box under steering wheel) causing the starter to turn but could not get the engine to take. I therefore assume the fault has something to do with immobiliser. Shorting out the relay was simply a test that I performed once to check if starter ok.
Back to the fault, if I turn the key and remove it and try again, the car eventually starts after many attempts. While these attempts are made a "brake light" warning is sometimes displayed on cluster screen.
Thanks.
Old 07-03-2008, 02:43 AM   #5 (permalink)
Photos: 0
Now can't get car to start at all!!!
I discovered that the white box IS the ews3 (3.3). During fault condition, pin4 is at 10v but when not in fault condition pin4 at 6.6v This is the only change in measured volts over all pins. Does anyone know the pinouts?
Old 07-03-2008, 10:15 AM   #6 (permalink)
Photos: 0
if you suspect EWS, find the black wire from ignition switch to EWS; and black wire fr EWS to starter. use a jumper to connect the 2 wires. car should start. If it still doesn't start EWS is not the problem
Old 07-04-2008, 12:25 AM   #7 (permalink)
Moderator
Dirty_Tool's Avatar
Photos: 0
The car will not start it will only crank and this will really not tell you anything.
I would try another key if you have one to try. That is the most common and logical failure. If that doesnt work then check fuse #s 12 and 37.
hopefully you have another key to try.
BTW pin # 4 is the S_DWA signal wire which goes from the EWS to the DME (engine module) A voltage measurement really isnt going to tell you anything. There is a individual serial # with rolling code technology that is sent across that wire back and forth between the EWS and DME. You can view it with an oscilliscope but even then you cant really translate it into anything useful. You need a good diagnostic machine like a GT1 or an autologic to tell you if it is a valid signal or not. The same type of machine would tell you if the key is valid or not as well.
DT
http://dtbmw.com/dt540
vB code is On
89 320i intermittant no start, HELP. yrshaik 3-Series (E21, E30) 6 12-31-2007 05:28 PM
Brake lights don't work-intermittant problem Pikespeakbob 5-Series (E12,E28, E34, E39, E60) 4 09-17-2007 09:56 PM
E39 528I intermittant electrical issues johnex 5-Series (E12,E28, E34, E39, E60) 7 05-24-2007 11:50 PM
Throtle response crazy91318 3-Series (E36) 2 09-17-2006 09:52 PM
Intermittant Missfires fitz1057 3-Series (E36) 1 09-11-2005 02:36 PM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
