Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 02-04-2004, 07:15 PM   #1 (permalink)
Photos: 0
stover is an unknown quantity at this point
I have a 1984 533i that is not holding idel. Once warn the engine goes into the strange cycle where it revs up to 1700 rpm and then back down to 1000 rpm and just keep going, back and forth as if it's searching for a corect idel rate. I can't afford to have a mechanic work on it. I know how to fix things, but this puzzels me to no end. any pointers from you BMW guys? I think it's vacuume related.
stover is offline   Reply With Quote
Old 02-04-2004, 08:39 PM   #2 (permalink)
Photos: 0
njtech is an unknown quantity at this point
start with cleaning the idle slide valve.(attached to the breather hose coming off the V/C) spray a little carb cleaner, let it dry and then give it a shot of WD40.
njtech is offline   Reply With Quote
Old 02-04-2004, 08:56 PM   #3 (permalink)
To the left ...
Torque's Avatar
Car: '90 535im
Photos: 0
Send a message via AIM to Torque Send a message via MSN to Torque
my dad's eagle was doing this... and it was a bad ECU . i dont know that anybody complained of BMW ECUs, but there is always a first
Old 02-04-2004, 10:51 PM   #4 (permalink)
EXtech's Avatar
Photos: 0
could be several things. What makes you think it's vacuum related? Did something occur to make you think so? It could certainly be vacuum related. I would check over all of your vacuum hoses and connections along with all of the intake ducting. As mentioned, I would also try cleaing your Idle air control valve. While it is idling and doing the surging, try tapping on the IAC with the handle of a good sized screwdriver. Sometimes those guys will stick and after a couple whacks, they will settle down. There is always a chance you could have an ECU problem and there could be other issues. Go with the easiest and obvious first.
STETT Performance -
Everything BMW
921 J Place, Suite 200
Plano, TX 75074
469-767-3309
OEM Repairs and Maintenance
Extended Warranty Service
Pre-Purchase Inspections
EXtech is offline   Reply With Quote
Old 02-05-2004, 05:09 PM   #5 (permalink)
Idle Member
E28boi's Avatar
Photos: 0
E28boi is an unknown quantity at this point
I do not believe that this is an ECU problem. It is your idle control valve or a vaccum line that goes to it. Check the vaccum lines that go to that valve. If they are in good shape, take out the valve and spray carb cleaner in it and shake it well. you should hear a ball moving back and forth. This is good. spray a little WD-40 in it and shake it up. Re-install it. Also there is a screw in the valve that you can use to adjust the idle. If this does not work, you will need a new valve. They are not cheap!
86 535i
99 Passat V6
E28boi is offline   Reply With Quote
Old 02-09-2004, 04:34 PM   #6 (permalink)
y2khris's Avatar
Photos: 0
y2khris is an unknown quantity at this point
I just saw this same exact problem on an E30 with an M20 and I suggested it was the Idle Control Valve, but that didn't help on this car, and it ended up being the ECU
If you show your BMW love, she will love you in return.
y2khris is offline   Reply With Quote
Old 02-22-2004, 10:42 PM   #7 (permalink)
Photos: 0
88m53453 is an unknown quantity at this point
If you need an idle valve,you may also find the idle conrl unit defective, Just cut it all out and install the factory euro idle control system for under 150.00. that will eliminate theentire foolishness of electronics controlling the idle. Then you will havenice simple mechanical devices contolling the idle,justa s BMW AG intended. I have done this on several at my shop and sold numerous others over the years
88m53453 is offline   Reply With Quote
vB code is On
533i E28 Hydraulic Booster Install raybryan 5-Series (E12,E28, E34, E39, E60) 2 10-26-2005 04:23 AM
1984 533i M5 Vin# Decode- Is It A Real M5 Help!!! mstrbimmer 5-Series (E12,E28, E34, E39, E60) 2 03-17-2005 04:42 PM
E28 533i Parts Car MiniMan Classifieds Sell & Buy 0 02-26-2005 10:02 PM
Wheels for '83 533i rhitt 5-Series (E12,E28, E34, E39, E60) 1 08-14-2004 02:11 AM
BMW '83 533i Info bmwm3gtr200 5-Series (E12,E28, E34, E39, E60) 2 12-17-2003 07:33 PM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
