530i : idle control valve stuck mechanically - BMW Forum - BimmerWerkz.com
Old 08-20-2008, 08:50 PM   #1 (permalink)
uthayan is on a distinguished road
The Fault code 20 reads: Idle Control Valve stuck mechanically.
Any suggestion to repair this ?
uthayan is offline   Reply With Quote
Old 08-21-2008, 03:31 PM   #2 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 95 525i
change ICV is the only solution...
Old 08-22-2008, 10:07 AM   #3 (permalink)
Thank You.
My car is only 80k , hence I tried cleaning it with WD40 & Q tips; dried it for 30 mins . Now the problem seems resolved.
Old 01-04-2010, 05:40 PM   #4 (permalink)
davido is on a distinguished road
i.c.v
normally you can just remove valve clean it i recommend acarb cleaner wynns or similar carbon tetrochloride based cleaner i.e electrical contact cleaner then lubricate lightly with brake fluid i do not reccomend wd 40 as leaves a residue which can cause further problems this problem with i.c.vs is quite commom and not just bmws see bimmerforums.com excellent article on cleaning with all photos to help you,regards david u.k member e39 523i.
davido is offline   Reply With Quote
vanos mechanically stuck? enemigo 3-Series (E36) 3 08-07-2006 11:18 AM
Idle Control Valve Bunny Capricorn 3-Series (E21, E30) 2 08-10-2005 03:37 PM
Idle Control Valve Gomerino 3-Series (E21, E30) 5 03-01-2005 02:19 AM
Idle Control Valve? Xx1Lethl50xX 3-Series (E36) 3 11-19-2004 03:11 PM
Idle Control Valve Help Robdrmer1016 3-Series (E36) 7 07-16-2004 02:15 PM
