530i (E39) Rough Idle/Stalling - BMW Forum - BimmerWerkz.com
Old 11-27-2009, 09:21 AM   #1 (permalink)
Car: 2002 530i
pfaber is on a distinguished road
Folks, I need some diagnostic help, and so does the car.
I've a 2002 530i that idles poorly and stalls at traffic lights. Actually, I've not experienced the stall but my wife has several times. I will attest to the rough idle. I used my Peake scanner and I get two major codes:
1. O2 Adaptation Limit
2. O2 Sensor Control Limit
There are a series of misfire codes for all cylinders but I thing these are the result or symptomatic of the above two.
Also, there is a sharp metallic or clacking sound underneath the intake manifold that is periodic. Sounds like a very loud soleniod action or perhaps a backfire.
The car has 120K on it so I've recently replaced all four O2 sensors and the plugs. Recently I found the rubber vacuum line to the Secondary Air Diverter Valve cracked so I replaced it and traced it back and replaced at the opposite end as it was also deteriorating.
I've also put a new throttle body on the car for another issue.
I really need some help with this. Thanks I appreciate it and so will my wife as she is now driving the old cherokee and wants the 5'r back.
pfaber is offline   Reply With Quote
Old 11-27-2009, 09:43 AM   #2 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
Did you clear the codes after you replaced the o2 sensors ?....If you did and these are new then I would say you have a vaccum leak or the MAF is playing up...unplug the MAF and see what happens..
Old 11-27-2009, 09:46 AM   #3 (permalink)
Car: 2002 530i
Sure did, and after I repaired the broken vacuum connection. Codes came right back. Thanks
Old 11-27-2009, 09:48 AM   #4 (permalink)
marti5's Avatar
Try unplugging the MAF....
Old 11-27-2009, 10:06 AM   #5 (permalink)
Car: 2002 530i
MAF News
I should have suspected that. I unplugged the MAF, the engine quit andI restarted. Smooth idle and no solenoid on steroids sound.
I recently replaced the MAF on my VW TDI. Those give you a pretty good sense of their failure. They start to slow down until the performance of the TDI rivals that of an old diesel rabbit; my old vw bus was faster (for a frame of reference). Unplug the MAF and it goes like a real car ought to.
I just wonder why there is no MAF code on the BMW or the VW. It must be a German thing.
Thanks, no off to BAP/GEON for that sensor.
Old 11-27-2009, 10:25 AM   #6 (permalink)
marti5's Avatar
Peake code reader dont seem to but carsoft V6.5 does, anyway glad you know what it is now, have a nice weekend.
Old 11-01-2010, 12:09 PM   #7 (permalink)
bwatters is on a distinguished road
I have exactly the same symptoms on my 2001 with 140K, including the solenoid on steroids noise. Did replacing the MAF solve the problem? That's a $400 part! Is the a way to test it to confirm it has failed?
bwatters is offline   Reply With Quote
Old 11-03-2010, 11:47 AM   #8 (permalink)
Rough idle update. When working my way into the ICV for cleaning I noticed my intake manifold runner valve was damaged. It was not longer connected at the actuator end of the flapper. I replaced the part last night and when I started it up, it purred like a kitten. Problem solved. Thanks for the DIY stuff that lead me to clean the ICV and ultimately to the root cause of the idle problem. I wouldn't have gotten to it without BimmerWerkz to guide me.
Currently Active Users Viewing This Thread: 19 (0 members and 19 guests)
2001 (m02) 530i Stalling Problem mmclaren 5-Series (E12,E28, E34, E39, E60) 5 06-14-2011 12:57 PM
HELP!!! E39 525d very rough IDLE but can't fix kmoekhan 5-Series (E12,E28, E34, E39, E60) 5 09-17-2009 10:58 AM
Rough idle & jumping idle ///M Power 3-Series (E36) 4 12-22-2008 05:20 PM
need advice/jumping idle,stalling stevd 3-Series (E36) 1 08-27-2004 09:24 PM
