530i : Control System Malfunction, Transmission Fault, Flat Tire Monitor - BMW Forum - BimmerWerkz.com
Old 09-10-2009, 11:55 PM   #1 (permalink)
uthayan is on a distinguished road
Lightbulb 530i : Control System Malfunction, Transmission Fault, Flat Tire Monitor
Got 2004 530i. When I drive slowly on local street, getting the following message on i-Drive display " Control System Malfunction, Transmission Fault, Flat Tire Monitor" , and switch to limp mode. Once I restart, message disappear and work normal.
*** It doesn't happen on Highway drive*** Is it related to Vaccum ( may be air leak ?).
*** I am getting this for last 2 month, put 5k since it started. Any suggestion? - Thank You
uthayan is offline   Reply With Quote
Old 09-11-2009, 12:00 AM   #2 (permalink)
You're likely on the hunt for a faulty sensor.
Old 09-11-2009, 12:15 AM   #3 (permalink)
530 i Transmission Fault + FTM fault +ABS Fault
Which sensor ? all 3 { Transmission + FTM + ABS }, do you have an idea of where they are located ?
Thank you
Old 09-11-2009, 03:03 AM   #4 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
A full diagnostics will tell you which sensor or what has malfunctioned.
Old 09-11-2009, 10:33 AM   #5 (permalink)
2004 - 530i: Malfunction
Thank you and will update as what the BMW dealer says. Hope it is not a costly repair
Old 09-10-2010, 09:56 AM   #6 (permalink)
topshotta45 is on a distinguished road
control unit malfunction
were you able to find the problem?
topshotta45 is offline   Reply With Quote
Tire Flat-spotting ErikB 5-Series (E12,E28, E34, E39, E60) 3 06-18-2005 01:09 AM
Flat Tire! LOS 5-Series (E12,E28, E34, E39, E60) 2 04-27-2005 08:37 PM
Tire pressure monitor sensitivity? alotomeat 3-Series (E46, E90) 0 07-21-2004 10:44 PM
Tire Pressure Monitor Wyld_thots 3-Series (E46, E90) 0 05-02-2004 12:20 AM
E60 run flat tire is flat!!! Silver4evr 5-Series (E12,E28, E34, E39, E60) 16 04-13-2004 04:58 PM
