530i 540i conversion/ head replacement - BMW Forum - BimmerWerkz.com
Old 04-08-2010, 01:39 PM   #1 (permalink)
weldmachine is on a distinguished road
i have a 95 530i with 175k on it. the motor has a bad lifter and blown head gasket. i am ontemplating replaing the head gasket and lifter (if i can figure otu which head and lifter is the problem, do you know how?). i am very mechanically inclined has build a hand fullof transmissions and engine work but never a bmw before. based on the amount of work which i do have time and the cost of parts i am wondering if it would be easier to put a used motor in from a 530i or a 540i motor. if i put a 540 motor in what would i need to do, are the computers and wires the same, mounting, ect. its an automatic by the way. so any input on doing a head job, replacing the motor, or dropping in a 540i motor would be great.
weldmachine is offline   Reply With Quote
Old 04-09-2010, 12:47 PM   #2 (permalink)
yaofeng is on a distinguished road
Replacing the motor is by far the easiest and less time consuming.
95 525i 5 speed 5/94,
94 540it built 3/93, converted to 6 speed w/a 93 e32 M60 engine
01 540it, 6/01
03 325i, 9/02
10 mini 6 speed
yaofeng is offline   Reply With Quote
Old 04-13-2010, 02:31 PM   #3 (permalink)
Car: 1995 530i & 1986 535i
jimoreno is on a distinguished road
Since you have a 95, you will need to do the EWS delete when using the M60B40 DME (from a 94). You will have to watch your right foot with the automatic tranny since the B40 has a different and stronger automatic transmission.
jimoreno is offline   Reply With Quote
530i replacement engine zaphod1962 5-Series (E12,E28, E34, E39, E60) 10 02-05-2009 12:37 PM
Head gasket replacement on 530i Beemster 5-Series (E12,E28, E34, E39, E60) 8 10-11-2006 08:12 PM
530i Or 540i schernov 5-Series (E12,E28, E34, E39, E60) 2 04-26-2005 09:19 PM
Blown 530i V8 Cylinder Head toomuchmetafred 5-Series (E12,E28, E34, E39, E60) 5 01-30-2005 11:54 PM
528i To 540i/m5 Conversion Franks528i 5-Series (E12,E28, E34, E39, E60) 1 12-23-2004 11:33 PM
