Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 05-15-2008, 08:24 PM   #1 (permalink)
Photos: 0
dirty diesels is on a distinguished road
530d E39 ( DDE ) light
Hi i have a 1999 530d that has an issue. It all started today when the starter packed up. I bought a new one and a friend offered to fit it for me ( bad mistake ). On removal of the old starter he dropped it which resulted in breaking crankshaft sensor which sits below starter. I buy a new one,he fits it and replaces new starter and everything going well until he rests his arm on the plastic fuel pipe that comes out the front of the fuel filter housing and snaps it clean off ( hes having a bad day ). I then buy another pipe which he replaced. Now ive turned the ignition on and there is this DDE light that has appeared with a curly line above it and now the car will not start. Does anybody have any ideas and point me in the right direction as wot could be the fault. Thanks for reading
dirty diesels is offline   Reply With Quote
Old 05-15-2008, 08:38 PM   #2 (permalink)
Photos: 0
witeshark is just really nicewiteshark is just really nicewiteshark is just really nicewiteshark is just really nice
That's the main engine control module fault indicator I think. Not sure, but maybe just a simple reset could get it running...
witeshark is online now   Reply With Quote
Old 05-16-2008, 06:26 AM   #3 (permalink)
Photos: 0
Thanks for your reply. I hope it is just a reset and nothing more major as the worst thing is not having a car to drive
Old 10-25-2008, 09:37 AM   #4 (permalink)
Photos: 0
russcooper is on a distinguished road
how is this rest ...i have similar problem with my 1997 r reg 525tds estate
it was running fine now the dde light is on when i drive and performance has gone down ..? any clues on reset or advice on workaround
russcooper is offline   Reply With Quote
Old 10-26-2008, 12:26 PM   #5 (permalink)
Photos: 0
tarlac is on a distinguished road
your new pipe may not be properly connected... air tight. It wouldn't start if sucking air. simple check.
tarlac is offline   Reply With Quote
Old 10-29-2008, 02:55 PM   #6 (permalink)
Car: 2001 BMW 525d auto
Photos: 0
stevecvo is on a distinguished road
It sounds like a problem with the fuel supply. I had problems a couple of years ago with my 525d. The DDE light came on and the engine would not run. It turned out to be a faulty sensor in the fuel tank. I later had a similar problem when a sensor gave trouble. This time the engine would run provided that the tank did not fall below half full.
Check the pipe that was replaced.
stevecvo is offline   Reply With Quote
Old 10-29-2008, 04:38 PM   #7 (permalink)
Photos: 0
gets worse
so i was told to change my fuel filter ...gets fuel filter (deisel) attemps to remove ....failed ...removed the whole fuel filter housing ....bangs hand on engine 2 nice knucle cust ..still canot remove filter ..remove all from car ..goes to garage to now hold unit and turn filter ...doh!! snaps lug for pipe to intake ....so who having bad day ...now i got to find a new ior part worn part ....any one know where i may obtain one from as now i got a bmw525 tds thats as usefull as a chocolate fire guard
Old 11-03-2008, 05:29 PM   #8 (permalink)
Photos: 0
MADDOUG is on a distinguished road
Check and make sure that the crank sensor wiring has been connected,engine will not start unless ecu knows crank position,failing that sensor may be connected but not fitted in bell housing far enough to get a signal.
MADDOUG is offline   Reply With Quote
Old 11-03-2008, 06:10 PM   #9 (permalink)
Photos: 0
lol
well here comes more fun ...rang today new bit cost ?£150
and to top that i aint got an e34 ..mine is later model e39 so it looks like am getting kicked from here soon eh ?lol
just now searching the the e39 forums ...same engine tho funny that ...ah well the railway glue worked ...car running agin ,. but now still got dde light and back to point 1 ...am gonna get it rest for £30 from a mate and see what happens ...i will let you all know soon
vB code is On
2000 530d e39 electrical problem RSK2831 5-Series (E12,E28, E34, E39, E60) 6 01-05-2007 08:11 PM
e39 530d warm start problem NiTrO 5-Series (E12,E28, E34, E39, E60) 1 01-03-2007 05:11 AM
e39 530d smooth 5-Series (E12,E28, E34, E39, E60) 0 07-09-2006 12:51 PM
DDE/City Light Switch 97alpineM3 3-Series (E36) 14 02-05-2006 12:07 AM
E39 530d Auto Leaking Gearbox Problem igk 5-Series (E12,E28, E34, E39, E60) 3 10-17-2004 10:31 AM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
