528i Weird noise - BMW Forum - BimmerWerkz.com
Old 03-30-2012, 01:30 PM   #1 (permalink)
maverick831 is on a distinguished road
528i Weird noise
Hi guys im new here i have a 2000 528i modeI and im getting a noise when my car gets warmed up and im driving it starts to make a whoooom noise i was thinking the power steer pump because when i turn Ieft or right the noise goes away and OnIy comes back when im driving straight but thinking i usuaIIy sIow down .When i go uphiII ony when car is warm Yu can reaIIy hear the sound WHooooM at idIe the car runs steady but sounds ike i may have a air Ieak i read the forms of a cvv but unsure. sometimes if i hit a good bump it sound as if something is Ioose making the noise Its Iike putting a muffIer on them taking it off can anyone heIp. I know i have to maintain and by parts yeary but i need this fixed first you can hear the noise as i get out the car
maverick831 is offline   Reply With Quote
Old 03-30-2012, 02:00 PM   #2 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
You seem to have several dash lights on. Was the car running or just the ignition on?
If you suspect its a power steering pump issue check for leaks. The pumps rarely fail unless they have no fluid in them. The power steering hoses are the weak link as they commonly leak. Replacing the hoses and reservoir when a leak is noticed is the best option. A power steering pump is around $350, the hoses and reservoir are a lot cheaper
Click HERE to see my E36 Blog
Old 03-30-2012, 02:12 PM   #3 (permalink)
Running
Yes the car was running i was driving it around tiII the noise started again i have the check engine Iights because i sent my abs moduIe in for repair this week but i have the Ieast cIue to the actuaI noise its not constant. but my Iower ps hoses are Ieaking a Iittie a thought i saw a permanent fix mod somewhere but not sure
Old 03-30-2012, 02:18 PM   #4 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
So if there leaking check and see from where. And check to see how much fluid is curt fly in the reservoir. If low, top it up right away. Then check to see if The sound remains.
Old 04-01-2012, 08:51 AM   #5 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
You could try adding a screw-clamp (Jubilee) to the crimped connectors to help reseal the pipes ! I would personally have them replaced...
Eso es todo!
BMW Part Market
BMW Online Manuals (TIS)
New Member ?
Old 04-01-2012, 10:05 AM   #6 (permalink)
westin is on a distinguished road
Its kinda hard to make out the, bit when you revved it i could almost hear what sounde like a bad pulluey,but it could have just been the recording grad a long screwdriver,and check the pulleys of hearing for noise ,be careful noise telescopes so put as close to pulley or component you want to hear apart from this hard to diag without being there.
westin is offline   Reply With Quote
Old 04-01-2012, 01:21 PM   #7 (permalink)
If you suspect its a power steering pump issue check for leaks. T he pumps rarely fail unless they have no fluid in them. The power steering hoses are the weak link as they commonly leak. Replacing the hoses and reservoir when a leak is noticed is the best option. A power steering pump is around $350, the hoses and reservoir are a lot cheaper
i did a gd check this time its Ieaking from the high side hose about 1 oz every 2 weeks it was a oz Iow but the noise is from the pick im posting
Old 04-01-2012, 01:24 PM   #8 (permalink)
Thanks for the manuaI i was tempted to buy one but yu saved me the trubIe
Old 04-01-2012, 01:34 PM   #9 (permalink)
i started there on the puIIies but the noise was hearabIe today it sound Iike a pretty good air Ieak but from where it appears to have a Iittie oiI n the front side of the engine I fIushed the ps fiuid which is red but this is brown coIored if im Iosing oiI the dip stick isnt reaiiy showing it i dont have the super charger but the noise is in the marked area. and if its the cvv can i get away with just buying the unit by itseIf and not the hoses
Old 04-13-2012, 08:21 PM   #10 (permalink)
new video
This shws the noise cIearIIY
Old 11-09-2012, 02:34 PM   #11 (permalink)
ARAL1974 is on a distinguished road
2000 BMW 528i Squeiling Noise at start
I have a problem but slightly different. I have a 2000 BMW 528i and have been experiencing a squeiling noise at idle speeds after cold start. Any ideas what could be causing this?
ARAL1974 is offline   Reply With Quote
Old 11-09-2012, 05:46 PM   #12 (permalink)
If you could post a video that would help a whole lot these bimmers make a lot of similiar noises when parts are going bad and its very difficult to diagnois. Post a video and more of the experienced guys on here could help you out better but the noise could be a pulley going bad but I tell you if you havent replaced then replace them they really dont last long
Weird Noise Nova 3-Series (E36) 4 05-20-2009 11:39 PM
Help Please! Weird Noise bimmerguy82 3-Series (E36) 6 05-19-2006 12:15 AM
Weird Noise Under The Car.. swanvesta 3-Series (E36) 2 07-12-2005 11:42 PM
Weird noises from '98 528i Bob_T 5-Series (E12,E28, E34, E39, E60) 8 09-20-2004 10:32 AM
Weird Noise BlantonG13 3-Series (E36) 8 05-18-2004 03:43 PM
