528e starting problems - BMW Forum - BimmerWerkz.com
Old 03-15-2009, 10:46 AM   #1 (permalink)
Car: 87 528e
daddio is on a distinguished road
Exclamation 528e starting problems
I bought an 87 528e for $400, which had the timing belt break and bent the valves. I replaced all the valves, water pump, ignition rotor, distributor cap, and plugs. when I started it the first time, it started right up, but the idle pulsed, and was rough, and would kill if I didn't give it gas. The lights flashed upon starting, and the check light keeps flashing, indicating a problem. Today, I went to start it, and the engine turns over, but does not start. I think it's getting fuel, because I can smell it at the engine. All fuses are good, and I think all the vacum hoses are on right. I didn't remove much, since I just propped up the planum while taking the head off. Any suggestions. Thanks Daddio
daddio is offline   Reply With Quote
85 528e starting Blatch 5-Series (E12,E28, E34, E39, E60) 4 12-06-2007 11:28 PM
Perplexing Problem Starting my 87 528e arkhaus 5-Series (E12,E28, E34, E39, E60) 5 02-04-2006 08:17 AM
My 84' 528e Starting Troubles... rock_martyr 5-Series (E12,E28, E34, E39, E60) 5 10-05-2004 10:37 PM
'88 528e Starting Problem Solved! jopa 5-Series (E12,E28, E34, E39, E60) 2 07-07-2004 09:24 PM
Problems with a 1984 528e Starting Unicorn 5-Series (E12,E28, E34, E39, E60) 5 06-14-2004 02:44 PM
