528e Heater Help - BMW Forum - BimmerWerkz.com
Old 11-16-2004, 07:07 PM   #1 (permalink)
sailor1313 is an unknown quantity at this point
My 1985 528e has a strange heat issue. The heat works fine below about 1700 rpms, above 2,000 the heat completely goes away. It is obvious that no coolant enters the heater core at the higher rpms. Slow down for an exit ramp or just run about 55 on the highway and there's plenty of warm air. But who drives 55?
Any ideas? It's getting cold here in New England
sailor1313 is offline   Reply With Quote
Old 11-16-2004, 08:06 PM   #2 (permalink)
'89 635 csi's Avatar
'89 635 csi is an unknown quantity at this point
Welcome! Let me ponder your question for a while.
Dave G.
'89 635csi
'86 528e - Sold
'84 528e - Soon to be 533i
'96 Jeep Cherokee 4WD
OO=[][]=OO
'89 635 csi is offline   Reply With Quote
Old 11-16-2004, 09:47 PM   #3 (permalink)
The only thing I can come up with is that maybe you have a very low temp thermostat in it and the faster you go the faster the water (i.e. water pump is moving faster) is circulating and it's not getting hot enough to warm the water efficiently. Or your heater core is on it's way out. These are the only things I can come up with.
Dave G.
'89 635csi
'86 528e - Sold
OO=[][]=OO
Old 11-17-2004, 07:00 AM   #4 (permalink)
[snapback]232336[/snapback]
Old 11-17-2004, 07:04 AM   #5 (permalink)
Thanks. The temp change is alomst instantaneous. The thermostat is new and the correct temp. I ruled out the heater core because it does work fine as long as there's hot water going into it. Is there a heat control valve that is vacuum operated?
Old 11-17-2004, 07:17 AM   #6 (permalink)
Yes. However I don"t think that the temp would change that quickly if it was the HCV. But I would check it out anyway.
Please keep me updated.
Dave G.
'89 635csi
'86 528e - Sold
OO=[][]=OO
Heater Problem Bmmf40 5-Series (E12,E28, E34, E39, E60) 1 07-03-2005 11:38 PM
Heater Core ? walshja 3-Series (E36) 8 01-19-2005 05:39 PM
Interesting Heater Behavior hockey_fan 3-Series (E36) 6 11-03-2004 11:24 PM
Analog to Digital Heater Conversion Digital318is 3-Series (E36) 3 04-02-2004 01:34 AM
Heater Problem in 1985 528e mahill69 5-Series (E12,E28, E34, E39, E60) 12 12-18-2003 08:44 AM
