Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 01-15-2004, 11:23 PM   #1 (permalink)
Photos: 0
IggoTong is an unknown quantity at this point
Hello!
Am new to the forum but couldn't help but registered because, like most of us, my '95 525i has reached the stage of needing "special" attention.
First off how do I verify the year model of the car? Although its registered as '95 model I have my doubts. Essentially I wanna make sure that the engine is an M50. Is there a way to verify this say in the engine number?
Second. It doesn't want to start. Battery's ok. Gear lever is in "P". When the ingition key is placed in the "ON" position everything on the dash is brightly lit, when its pushed to the "START" position the engine doesn't crank. Dash display doesn't dim when this is done. issed2" class="inlineimg" />
Third. Breaks squeek like hell when pressed lightly and sound disappears when pressed hard. issed2" class="inlineimg" />
Let's keep it short for the meantime to elude myself from thingking that I purchased a dud.
IggoTong is offline   Reply With Quote
Old 01-16-2004, 01:35 AM   #2 (permalink)
Photos: 0
My car also does the break squeaking when light and goes waway with pressure....
unless your car is older than 91, it has the m50, some ways to check is to see if the valve cover gasket is black and the intake manifold doesnt look like a spider sitting over the top of the valve cover.
Also your car is a 1995 if you have a wide front grille, look at my sig and see if yours is wider, if so - its a 95
Old 01-16-2004, 04:10 AM   #3 (permalink)
Photos: 0
Yup its a '95 then..thanks!
Any comments/views/suggestions on the starter? Have you encountered the same problems with your car?
Old 01-16-2004, 12:01 PM   #4 (permalink)
CBA
CBA's Avatar
Photos: 0
CBA is an unknown quantity at this point
Send a message via MSN to CBA Send a message via Yahoo to CBA
could very well be the starter, possibly the ground have a look around.. or the ignition switch.
your brakes squealing and stop when you apply hard.. time for new pads thats the pad wear sensor causing the squeal.. take care of that soon as the pad sensor might take a bite outta your rotor.
all you ever need for the toronto night life <a href='http://www.spotlighttoronto.com' target='_blank'>click here</a>
<img src='http://www.spotlighttoronto.com/forum/templates/DigitalDementia/images/header.jpg' border='0' alt='user posted image' />
you know your not paying attention when this happens:
<div class='quotetop'>QUOTE</div><div class='quotemain'>Are you refering to his Signature? oh shit, i just remembered i used my name in my sig... I just 0wn3ed myself. </div>
-Founder
CBA is offline   Reply With Quote
Old 01-18-2004, 04:43 AM   #5 (permalink)
Photos: 0
ok here's the verdict...the starter's shot because of an installed booster that caused the latter to burn...rewinding is needed... ghead
any suggestions on what brand of break pads to get? some one told me Bendix are ok...
Old 02-01-2004, 06:57 AM   #6 (permalink)
Photos: 0
what is the best plus size with out losing original ride comfort? is it ok to go from stock to plus 2 with out changing stock suspension? i've been thinking of getting those M5 parallels for a while now and couldn't decide because the change might impede a good ride...
commets please....
Old 02-01-2004, 11:01 AM   #7 (permalink)
To the left ...
Torque's Avatar
Car: '90 535im
Photos: 0
Send a message via AIM to Torque Send a message via MSN to Torque
a lot of people are using m parallels and nobody complained so far... i dont recommend you go over 17
vB code is On
95 525i engine TDC w/VANOS yaofeng 5-Series (E12,E28, E34, E39, E60) 0 11-06-2005 06:39 PM
Used 525i rszanto 5-Series (E12,E28, E34, E39, E60) 2 09-06-2005 05:36 PM
E28 - Is The Radiator The Same On The 525i & 528i? roscoa1 5-Series (E12,E28, E34, E39, E60) 0 01-08-2005 03:28 PM
Z3 And 525i dahrich 5-Series (E12,E28, E34, E39, E60) 4 10-14-2004 12:18 PM
325i vs 525i Bengal94 3-Series (E46, E90) 2 10-25-2003 10:51 PM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
