525i M50 vanos ..HELP! - BMW Forum - BimmerWerkz.com
Old 08-12-2008, 07:20 AM   #1 (permalink)
jonasdl is on a distinguished road
Hello Everyone!!!
Have a problem with my Bmer! When I step on the gas pedal, there's a hesitation on the engine! It seems the RPM had a hard time reaching the 2-3000 mark!!! But sometimes it doesn't do that!!! When in idling, it seems everything is OK!, but when you step on the gas pedal, engine runs rough, kinda misfiring and popping sound..
I already checked coil packs, throttle body, TPS, Airflow sensor (MAF), manifold hoses....replaced Plugs, new valve cover gasket, done oil change, new fuel filter and replaced a/t fluid.
Read about cleaning ICV...but can't find it's location?
When I drove the car, it seems that fuel is not reaching the injectors...but the car never stall/s! Its not hardstarting either.
Thanks in advance!
jonas
jonasdl is offline   Reply With Quote
Old 08-21-2008, 06:06 PM   #2 (permalink)
Fixed the problem!
Tried to check the fuel pump! when i removed it, the pre-filter at the tip of the pump was cut open....dirt went inside the pump which cause the hesitation.... Replace the fuel pump and the problem was GONE!
Old 08-21-2008, 08:16 PM   #3 (permalink)
Glad to hear it!
Old 08-22-2008, 05:19 PM   #4 (permalink)
BBenedict's Avatar
Car: 2002 BMW 540i, sport package
BBenedict is on a distinguished road
Good job. Thanks for the info.
BBenedict is offline   Reply With Quote
fs: non-vanos m50 intake manifold Torque OEM Parts 0 03-09-2008 09:22 PM
M50 Non Vanos Cam WALSRU Looking For 0 10-01-2006 02:39 PM
M50 Vanos Help marlindreamer 3-Series (E36) 2 02-25-2005 10:15 AM
Did the 92 m50 e34 engines have VANOS? dubumb 5-Series (E12,E28, E34, E39, E60) 3 03-17-2004 05:53 PM
M50 NON VANOS parkerurban 3-Series (E36) 0 03-03-2004 09:23 PM
