520i E34 starting / running problems - BMW Forum - BimmerWerkz.com
Old 05-17-2010, 03:50 AM   #1 (permalink)
Car: 520i SE Touring 1996 E34
buxted69 is on a distinguished road
Unhappy 520i E34 starting / running problems
Hi everyone, my 520i touring has approx. 160k on clock, bought the car about 3 weeks ago and has been fine starts 1st time etc. Was fine on Friday and parked up, about an hour later difficult to start and very lumpy running and would cut out, managed to limp home. Have had spark plugs out and all fine there, noticed split hose that comes from the underside of the main air tube near the throttle ass'y. Covering the split with my hand made a difference, so cut pipe and rerouted to form a seal and although was better didn't fix the problem. Then noticed a 1/4" vacum hose from top of crankcase was completly perished and in 2 bits so replaced this with a bit of pvc tubing to try and prove a point. There was quite a bit of oil in the air filter box and the main air duct. Car now starts and runs sweet on tickover but will only run sweet up to 1500 rpm then will splutter and die. Not sure if the dodgy vacum hoses have caused a problem elsewhere. Some of the others also look perished. Can't understand the initial problem that car ran ok and then didn't an hour later - that seems more like a deffinate fault as the hoses have probably been perished for a while. Could oil also now be blocking any of the other vacum / breather hoses that would cause the lack of power?
buxted69 is offline   Reply With Quote
Old 05-17-2010, 08:48 PM   #2 (permalink)
roma's Avatar
roma is on a distinguished road
2 muche oil in intake ,DISA VALVE or AIR CONTROL VALVE but for oil in intake OIL SEPERATE GOD LUCK
roma is offline   Reply With Quote
Old 05-18-2010, 04:40 AM   #3 (permalink)
Cheers, got a mobile diagnostics man coming on wednesday so i'll post results so all can see in case of similar problems.
e34 525i auto - problems starting from cold Mr-Dee 5-Series (E12,E28, E34, E39, E60) 5 03-22-2010 04:06 PM
Please help! E34 520i problems starting then auto box goes into limp????? gregs07 New Members Check In 0 11-19-2009 01:56 PM
E34 M5 memory power seats into E34 520i KevinK 5-Series (E12,E28, E34, E39, E60) 2 11-01-2009 11:25 PM
E34 diesel starting problems e34Bill 5-Series (E12,E28, E34, E39, E60) 1 08-23-2007 04:31 PM
