1999 5 series water condensation under rear seat - BMW Forum - BimmerWerkz.com
Old 06-30-2012, 03:39 PM   #1 (permalink)
racertm184 is on a distinguished road
I have a 1999 5 series and just had to have the rear seat leather replaced. When the shop removed the rear seat they discovered a pool of water on the base of the seat. The shop checked the drain lines and door vapor seals.
The drain tubes and seals were all clear and there was no water leaking from those areas. I live in Florida and we just had record rain fall there was no sign of water leaking into the car from any of the normal problem areas.
Three day after the rain stopped and the weather has been very hot and humid, there are signs of condensation water beads forming around the access ports to the fuel tank and from under the sound proofing on the under seat base.
Does anyone have any information on how to correct this problem or has anyone had a similar problem.
Thank You
racertm184 is offline   Reply With Quote
1999 e46 318 losing water CR+DR-Ltd 3-Series (E46, E90) 19 11-24-2009 08:12 AM
1999 328ic convertable rear seat removal rjs 3-Series (E36) 1 07-29-2008 08:04 PM
Condensation/Water in headlight arh 5-Series (E12,E28, E34, E39, E60) 1 07-05-2007 07:13 PM
Moisture (water Actually) Behind Driver Seat jwamerica 3-Series (E36) 1 11-21-2004 05:47 PM
