04 525 GPS install Q's....... - BMW Forum - BimmerWerkz.com
Old 05-04-2004, 06:26 PM   #1 (permalink)
TECH's Avatar
I want to install a gps system in a '04 525. one wire hooks directly to the battery. the other has to be ignition controlled. Where in the trunk can I locate an ignition controlled lead wire or can I use any of the empty fuse spots?
The above question was posted by myself as a request from another person/member that couldn't do it themselves for some reason....
I'd say that any empty fuse terminal that has the switched power you need should do fine.
Ipod / Icelink Install W/ Photos - Concealed Ashtr WindowPro Audio and Electronics 0 12-29-2004 12:06 PM
HEADLIGHT/DDE INSTALL? kraze0g 3-Series (E36) 3 08-19-2004 07:47 PM
Another E39 aftermarket H/U install.....SOS! Endangered Beatz Audio and Electronics 6 05-31-2004 10:26 PM
