'01 530i Overheating PLEASE HELP! - BMW Forum - BimmerWerkz.com
Old 07-06-2007, 10:51 AM   #1 (permalink)
slate530i is on a distinguished road
Hi, my 2001 530i seems to overheat once every 3-4 months, I open the hood and there is no coolant. I filled it with water and its been ok. My mechanic tells me that he doesn't see a leak. What else could be eating my coolant?
slate530i is offline   Reply With Quote
Old 07-06-2007, 01:58 PM   #2 (permalink)
Trevize's Avatar
Trevize will become famous soon enoughTrevize will become famous soon enough
Send a message via AIM to Trevize
bad filler cap.
The spring gets weak and lets it leak when hot/under pressure.
Trevize is offline   Reply With Quote
Old 07-06-2007, 03:36 PM   #3 (permalink)
cnn
cnn is on a distinguished road
Consider a COOLING SYTEM OVERHAUL
Cooling system consists of many many parts that work together.
If you have more then 80-90K, consider doing the whole cooling system. On the long run, it costs less. Here is my write-up:
ENTIRE COOLING SYSTEM REPLACEMENT Tips and Tricks (Very Long, Enjoy!)
HTH...
cnn is offline   Reply With Quote
Old 08-07-2007, 12:29 AM   #4 (permalink)
kurtdaniel's Avatar
kurtdaniel is on a distinguished road
One possible reason a car for overheating is that antifreeze is not circulating through the engine as it should. Antifreeze serves two purposes. It not only keeps the engine temperature level during the winter ( preventing the engine from freezing) , it also keeps cars from overheating during the warmer months..try changing radiator.
Last edited by drz; 08-24-2007 at 10:31 AM. Reason: removed commercial link under suspicion of spam
kurtdaniel is offline   Reply With Quote
Old 08-07-2007, 09:57 AM   #5 (permalink)
Car: 00 Prelude, 95 525i, 85 635CSi
d3ity will become famous soon enoughd3ity will become famous soon enough
Replace the resivour cap and the coolant expansion tank bleed screw, shouldn't cost you more than 25 bucks for everything shipped to your door.
Also make sure your current bleed screw is tight!
d3ity is offline   Reply With Quote
Old 09-05-2007, 10:36 AM   #6 (permalink)
H8.2.B3.U's Avatar
H8.2.B3.U is on a distinguished road
Send a message via MSN to H8.2.B3.U
i had the same problem in my 01 530i sport turns out the water pump was on its way out n would play up every now and then replacing it with a steel one is best option especaily if you drive your car hard as i do , it is one of the weakpoints on the car , hope u get it fixed up =]
H8.2.B3.U is offline   Reply With Quote
Old 09-05-2007, 08:08 PM   #7 (permalink)
tony moss is on a distinguished road
check waterpump bypass pipes at rear of waterpump & engine.slow leaks are hard to detect. also change bottle cap.
tony moss is offline   Reply With Quote
Engine Overheating doughnutboy 3-Series (E36) 11 06-13-2005 02:10 PM
Custom 530i Or M3? Rugged530i 5-Series (E12,E28, E34, E39, E60) 2 01-15-2005 06:45 PM
FS: 2001 E39 530i - PERFECT CONDITION JCz04Bimmer Classifieds Sell & Buy 1 07-03-2004 10:47 AM
2002 530i w/ angel eyes crayzehpnoy85 5-Series (E12,E28, E34, E39, E60) 0 03-30-2004 11:53 AM
