'00 e39 stage 1 dinan help - BMW Forum - BimmerWerkz.com
Old 12-09-2008, 10:53 PM   #1 (permalink)
MLF540i is on a distinguished road
I have a few questions for those more experienced than I about the engine and how to drive it. First off, where is the icv and vanos located? Where is the MAF (I have the dinan cold air intake) How do I get to the intake's airfilter?
Ok, driving. This car has a ton of power and I find myself peeling out while taking off and switching gears, which really slows me down. Also, the power at lower rpms is sweeeet and not so sweet at the higher end. Any mods I can make to help? Any mods left outside of a major upgrade?
anyone with any info please help
MLF540i is offline   Reply With Quote
Old 12-09-2008, 11:33 PM   #2 (permalink)
Vanos is one of the BMW variable valve timing systems; it doesn't have any one location. The MAF (mass airflow sensor) should be in the OEM (stock) location, since moving it is irrelevant to detecting the greater air intake from the cia (cold air intake). The air filter should be very easy to locate.
Old 12-10-2008, 08:11 AM   #3 (permalink)
I am Teh Edumacator.
Teh Prof's Avatar
The air filter is located at the end of the intake pipe behind the front bumper.
In a 2000 E39, there is no ICV. The function of the ICV is handled by the electronic throttle body.
Lindsay fan club member.
Old 12-10-2008, 03:10 PM   #4 (permalink)
cipher's Avatar
Car: 1997 bmw 540i
cipher is on a distinguished road
do you have the dinan software installed? I had the dinan air intake and power chip installed with a new exhaust and cats. The car has great all around power but when you hit 4000 rpms the power gets much stronger. Between 4000 and redline it screams and after every shift (unless no traction) the car lunges forward. you shouldn't have less power at higher rpms
cipher is offline   Reply With Quote
Old 12-10-2008, 07:49 PM   #5 (permalink)
I am not sure. I know that I have the chip, cai, and exhaust. I am not sure if the software was installed as I bought the car with the upgrades put in already.
Old 12-11-2008, 07:58 AM   #6 (permalink)
Teh Prof's Avatar
The "chip" is the software. Actually, on your car, there is no new chip, there's just a software change.
Fs 1996 M3 Dinan Stage Iii Supercharged sugi14 Cars For Sale 5 05-27-2005 12:25 AM
Dinan Stage 1-2 Susp. Vs H&r/bilstein theogill 3-Series (E36) 2 10-19-2004 11:20 PM
Dinan Stage 2 Ecu Upgrade NeverLeaned 3-Series (E36) 5 10-10-2004 09:20 PM
Dinan Stage 1 Suspension SpeedInfusion 3-Series (E36) 14 10-10-2004 11:38 AM
Dinan Stage 1 Coming Soon komodo 3-Series (E36) 0 10-07-2004 06:42 AM
