00' 540i Coolant Spooting Out Of Screw? - BMW Forum - BimmerWerkz.com
post #1 of 4 (permalink) Old 05-15-2005, 09:31 PM Thread Starter
Greg T is an unknown quantity at this point
Hi I have a 00' 540i. Recently I noticed that coolant was leaking underneath the car. I opened the hood and noticed that the plastic screw near the expansion tank was spouting coolant (says entluftn near the screw). After the car cooled down I removed the big plastic screw and noticed that it went into a hose that hooked into the top of the expansion tank.
Do I need to replace this screw? or does coolant leaking from this screw indicate another problem, like too much pressure in the system.
Greg T is offline
post #2 of 4 (permalink) Old 05-17-2005, 09:07 PM Thread Starter
Any ideas of what this screw is for? I'll take a picture if that will help.
Greg T is offline
post #3 of 4 (permalink) Old 05-18-2005, 09:14 AM
that is your bleeder screw. when your filling the coolant system up aftre a change you have to take that out and fill it up until coolant comes out of the hole then you would put the screw back in and proceed to bleed the cooling system. i doubt that there is anything wrong other than a leaky bleeder screw. either on the screw or in the hole look for a little rubber o-ring. that needs to be there for the screw to seal. i'd prolly just go and replace the screw, it is and easy inexpencive fix. if a alot of coolant has drained out you of course will definatly want to top it up but you might want to re-bleed the cooling system, to make sure there are no air pockets anywhere in the system.
bryan1970 is offline
post #4 of 4 (permalink) Old 05-20-2005, 08:43 AM Thread Starter
Thank you, it was a $3.25 part. It seemed to have stopped the leak. Normally I would have taken it in, thank you for the savings.
Greg T is offline
Vin Number skimmilk 5-Series (E12,E28, E34, E39, E60) 1 12-16-2004 06:07 PM
coolant dropping -- due to broken cap RedBeemer95 3-Series (E36) 3 09-12-2004 10:48 AM
VIN CHECK wax Bimmer Talk/Motorsports Talk 3 07-11-2004 06:34 PM
Coolant Question charles01 3-Series (E21, E30) 1 03-06-2004 07:57 PM
Coolant problem on 2000 540i bccwu 5-Series (E12,E28, E34, E39, E60) 7 12-16-2003 05:51 AM
