Yellow Oil Light Stays On After Engine Is Off - BMW Forum - BimmerWerkz.com
Old 01-21-2005, 03:06 PM   #1 (permalink)
BimmerDom's Avatar
BimmerDom is an unknown quantity at this point
Why does a yellow "oil" idiot lamp sometimes stay on after I turn off the engine.. this is intermittent.
2004 325i
2004 325i Sport Package
Stock for now, but for how long???
BimmerDom is offline   Reply With Quote
Old 01-21-2005, 05:45 PM   #2 (permalink)
2001BMW325xi is an unknown quantity at this point
Originally posted by BimmerDom@Jan 21 2005, 03:06 PM
Why does a yellow "oil" idiot lamp sometimes stay on after I turn off teh engine.. this is intermittent.
2004 325i
[snapback]276245[/snapback]
Just means that your oil levels are running a lil low. Its intermittent depending on how the oil levels are at various points of the day (driving raise sand lowers levels). Just go to your auto dealer and buy a quart of their best synthetic oil (Mobil 1 ought to do).....and pour in a little into the brake reserviour following the instructions in the manual ( assuming you have one). Remeber not to add too much. The light will go away.
Ciao and dont fret too much....bimmer's lights usualy like scaring ya more than anything....read the manual and it answers most common questions.
2001BMW325xi is offline   Reply With Quote
Old 01-21-2005, 06:47 PM   #3 (permalink)
zibby's Avatar
Car: yes
sehey man are you crazy, you told him to put engine oil to brake reservoir ?!!!
Be cerful who you trust on this forum !!!
http://www.q8oils.it/
Old 01-21-2005, 06:59 PM   #4 (permalink)
billB's Avatar
Originally posted by 2001BMW325xi+Jan 22 2005, 12:45 AM--><div class='quotetop'>QUOTE(2001BMW325xi @ Jan 22 2005, 12:45 AM)</div><div class='quotemain'><!--QuoteBegin-BimmerDom@Jan 21 2005, 03:06 PM
2004 325i
[snapback]276345[/snapback]
[/b][/quote]
Wrong Information......NEVER ADD MOTOR OIL INTO BRAKE FLUID RESERVIOUR. YOU MAY CHOOSE CORRECTION/EDITING OR IT WILL BE DELETED> THANKS
BillB
Old 01-22-2005, 12:45 AM   #5 (permalink)
doughboyea's Avatar
doughboyea is an unknown quantity at this point
Send a message via AIM to doughboyea Send a message via Yahoo to doughboyea
I'm not a mechanic, but still..
I don't know if the computer on the '04 models is different in that reguard, I'd call the dealer and ask them, not that you'll get a good answer, that does sound odd to me, then again, I don't have an '04 model.
Dough
<img src='http://img.photobucket.com/albums/v298/doughboyea/car3.jpg' border='0' alt='user posted image' />
<span style='color:green'><u>Proud</u> Member of the BMW Community</span>
<span style='color:black'>1999 BMW 328i Jet Black
--Total Dinan Points: 5 --
<a href='http://dinancars.com/SeriesPrint.asp?prod=335' target='_blank'>----</a>Dinan Stage 1 Suspension<a href='http://dinancars.com/SeriesPrint.asp?prod=335' target='_blank'>----</a></span>
<span style='color:black'><a href='http://www.ajusa.com/cgi-bin/knfilters/start?r=ajusa&ajr_skey=e2398f2ee8c6388757f9e7fb800 a4cb9' target='_blank'> --</a>K&amp;N Air Filter<a href='http://www.ajusa.com/cgi-bin/knfilters/start?r=ajusa&ajr_skey=e2398f2ee8c6388757f9e7fb800 a4cb9' target='_blank'> --</a></span>
doughboyea is offline   Reply With Quote
Old 01-22-2005, 12:50 PM   #6 (permalink)
storme's Avatar
storme is an unknown quantity at this point
i think you are all wrong,,,,on my 2004 e46 bimmer the RED light is oil and the YELLOW light,,that looks like an engine,is the engine check light,,for the emmisions
if it stays on it means the emmisions values have deteriorated
also if it is the RED oil light,,and it stays on AFTER the engine is switched off,then it is the oil levels!!!page 137 of the manual
hope this helps
and get the colours right :-)
visit me at <a href='http://www.storme.co.uk' target='_blank'>www.storme.co.uk</a>
visit me at http://www.janspeed.com
storme is offline   Reply With Quote
Old 01-22-2005, 02:25 PM   #7 (permalink)
zibby's Avatar
Car: yes
hope this helps
[snapback]276828[/snapback]
We are not wrong , on this cars (also on yours ) red engine oil light is for low pressure you have to stop car immediately when it comes on while driving. The same light come on with a different color (yellow),when oil level is at the absolute minimum. (also stay on with the engine off to tell you that you have to add some oil)
Old 01-24-2005, 07:22 AM   #8 (permalink)
BimmerDom's Avatar
Yikes.... looks like I got a straight answer
I researched the entire manual, here is the answer (page 19)
Yellow Engine Oil Level comes on after the engine has been switched off: add engine oil at the nearest opportunity...
Old 01-24-2005, 02:54 PM   #9 (permalink)
x94x is an unknown quantity at this point
I purchased a new 2004 330xi in July. I called the dealer when the yellow oil light stayed on after I turned off the car. They said that this usually happens around 6000mi - it just means that the oil was a little low. I stopped in at the dealership and they topped it off at no charge - in and out in 10 minutes.
x94x is offline   Reply With Quote
Old 01-25-2005, 10:20 AM   #10 (permalink)
[snapback]278016[/snapback]
[FONT=Times]LIKE I SAID
HEY ZIBBY AND BILLB........make sure you know what yure talking about before you accuse someone of posting wrong info. At least read the post properly....JEEZ
Old 01-25-2005, 12:54 PM   #11 (permalink)
AIO
AIO's Avatar
AIO is an unknown quantity at this point
Originally posted by 2001BMW325xi+Jan 25 2005, 10:20 AM--><div class='quotetop'>QUOTE(2001BMW325xi @ Jan 25 2005, 10:20 AM)</div><div class='quotemain'><!--QuoteBegin-BimmerDom@Jan 24 2005, 07:22 AM
[snapback]278804[/snapback]
[/b][/quote]
So you think the manual says 'pour engine oil into the BRAKE RESERVOIR'????
<img src='http://www.photoforums.com/photopost/data/500/2175banner1.jpg' border='0' alt='user posted image' />
AIO is offline   Reply With Quote
Old 01-25-2005, 06:40 PM   #12 (permalink)
rgzimmer is an unknown quantity at this point
It could also be a fauly oil sensor like mine. I had the light start coming on around 8k, but the oil level was fine. Dealership replaced the sensor and my oil for me per SIB 11-07-03
2004 325CiC Convertible; Silver Gray Paint, Gray Leather, Black Top, Sport Package, Premium Package, Xenons, heated seats, but too cheap to buy the nav...
<img src='http://webpages.charter.net/rgzimmer/sigo.JPG' border='0' alt='user posted image' />
rgzimmer is offline   Reply With Quote
Old 01-25-2005, 07:57 PM   #13 (permalink)
white 330ci is an unknown quantity at this point
ya just check you oil level the old fasioned way. with the dipstick...
and do not put engine oil into your brake resivoir, i think he just made a typo.
white 330ci is offline   Reply With Quote
Old 01-25-2005, 09:04 PM   #14 (permalink)
zibby's Avatar
Car: yes
[quote=2001BMW325xi,Jan 25 2005, 11:20 AM]
Originally Posted by BimmerDom,Jan 24 2005, 07:22 AM
Yikes.... looks like I got a straight answer*
[/q
uote]
Yes ! we red your info and you B S owners of those great cars ,tellin them to pour engine oil into brake fluid reservoir and jeopardazing their safety - this is unacceptable on this forum !!!!!
Old 01-26-2005, 03:21 PM   #15 (permalink)
jkloese's Avatar
jkloese is an unknown quantity at this point
I had the yellow/amber oil light come on in mine at about 55000 miles and it turned out to be the oil level sensor not the low oil. Just thought thought i'd add my experience in there.
<img src='http://www.bmw-forums.com/forum/index.php?act=Attach&amp;type=post&amp;id=18826.jp g' border='0' alt='user posted image' />
jkloese is offline   Reply With Quote
Service Engine Soon Light Zapak4eva 3-Series (E46, E90) 3 09-06-2005 08:55 PM
Check Engine Light E46 '04 M3 frw73 M-Series (M1, M3, M5, M6) 4 08-24-2004 10:20 PM
Check Engine light went away Ferrahs 3-Series (E36) 14 07-17-2004 02:32 PM
loud engine noise and check engine light steviebhoy 3-Series (E36) 4 06-04-2004 06:59 AM
check engine light and check light Scarface 3-Series (E36) 3 06-03-2003 08:31 AM
