Yellow Oil Light - BMW Forum - BimmerWerkz.com
Old 04-01-2006, 05:50 PM   #1 (permalink)
dellop is an unknown quantity at this point
Yellow Oil Light
About 30 seconds after my car (01 325xi) is running, the yellow oil light will come on for about another 15 seconds then turn off. I checked my oil level and it was right in the middle between min and max. I added enough to put it to the max, but it still occurs. It started doing this a few weeks ago and only does it just after starting the car.
Any ideas?
dellop is offline   Reply With Quote
Old 04-01-2006, 07:52 PM   #2 (permalink)
325isBaby's Avatar
Car: 2005 330xi
could be a faulty oil level sensor if this is not just the normal light check that occurs.
Come see me at MySpace
Old 04-04-2006, 08:51 AM   #3 (permalink)
Update-
When I switch the ignition on, but the car is not running, there is no light at all being displayed for oil. But if I let the car sit without running, what about 15 seconds, the red oil light will eventually light (just like the battery and such, as expected i think). Then the yellow light is not displayed after the car is started.
Is this normal behavior? That, if I start the car right away, it takes a minute or so for the oil sensor to engage and therefore is testing itself while the car is running?
Old 04-04-2006, 02:16 PM   #4 (permalink)
441tech's Avatar
441tech is on a distinguished road
Sounds like the oil level sensor to me.
Officer: "I see you set the table for four."
Groucho Marx: "That's nothing--I set my alarm clock for eight."
441tech is offline   Reply With Quote
Old 04-04-2006, 03:39 PM   #5 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
We have seen this issue at the shop I work at a few times with the E46's. Usually a new oil level sensor/switch fixes the problem.
My M50 Powered E30 Page
Old 04-04-2006, 06:12 PM   #6 (permalink)
Would that be the Oil Levelling Sensor (found at the bottom of the oil pan)?
oil service light help hawky1 3-Series (E36) 3 06-09-2009 01:32 PM
Oil Service light fredrex 1,6,7,8 - Series and Mini Cooper 2 01-14-2006 04:44 PM
Engine Light + EML light yellow alerts ththeodosis 3-Series (E46, E90) 1 11-20-2005 08:47 AM
