yellow oil can light - BMW Forum - BimmerWerkz.com
Old 04-22-2004, 08:59 PM   #1 (permalink)
gonzo499's Avatar
gonzo499 is an unknown quantity at this point
a couple of q's...the yellow oil can looking light above the speedo keeps coming on for like thirty seconds and then turns off. this seems strange because i just had the inspection 2 done a week and a half ago and all they said was that my thermostat housing is cracked and my bushings are torn. they said nothing about the oil or the oil light. i called them and they told me to check the level which i did and was ok. why would it be low....they just changed the oil 8 damn days ago! anyway, any insight would be appreciated.
also, i used to detail cars when i was sixteen and had the opportunity to drive a bunch of different bimmers. i distinctly remember the display saying welcome when i turned the car on. mine does not. it doesn't give me any kind words of greeting-just the countdown to my next oil change. its ok i guess but i'm just curious if all your e46's do the same.
<img src='http://www.bmw-forums.com/forum/uploads/post-4-1081744190.jpg' border='0' alt='user posted image' />
<span style='color:gray'><span style='font-family:Arial'>2000 323Ci alpine white</span></span>
gonzo499 is offline   Reply With Quote
Old 04-22-2004, 09:01 PM   #2 (permalink)
gonzo499's Avatar
i'm also wondering about your opinions about the urethane powerflex bushings. good? bad? so-so? also if there were any noticeable differences after you swapped them.
Old 04-22-2004, 09:54 PM   #3 (permalink)
Braymond is an unknown quantity at this point
Send a message via ICQ to Braymond Send a message via AIM to Braymond Send a message via MSN to Braymond Send a message via Yahoo to Braymond
The light... I dunno
The Display... I know Five Series and up do that, i haven't seen a 3 series do that tho.
The Bushings.... a must, the stock ones lick nuts, and although I did buy Poly Urethane ones, the shop installed M3 ones... oh well those are better then the stock ones anyway
-B
<a href='http://www.ipccomputers.org' target='_blank'>My 'in-progress' Business</a>
<img src='http://www.ipccomputers.org/DSC01118.jpg' border='0' alt='user posted image' />
2001 330i
Braymond is offline   Reply With Quote
Old 04-23-2004, 07:22 PM   #4 (permalink)
gonzo499's Avatar
how much do the m3 bushings go for?
and would torn bushings cause my car to pull gently to the right?
Old 04-23-2004, 09:04 PM   #5 (permalink)
CiscoKid's Avatar
nice sig
Old 04-24-2004, 04:37 AM   #6 (permalink)
The bushings I got were 125 installed. And no, i doubt it will fix your pulling problem. Many will sit here and tell you it will, but I still doubt it. I have had every damn part looked at front and back and my car still jerks to left, freaking irratates me to no end.
-B
2001 330i
Old 04-26-2004, 06:53 PM   #7 (permalink)
TECH's Avatar
-B
Tires? Try moving them side to side, unless you've got directionals.
Old 04-26-2004, 06:54 PM   #8 (permalink)
TECH's Avatar
There is an oil level sensor in the oil pan that can go bad, causing the light to come on. Changing it will require dumping the oil again.
Yellow Oil Light On, But Oil Level Is Perfect bbensten 3-Series (E46, E90) 8 02-28-2005 07:57 AM
Yellow Oil Level Light Comes On Then Goes Off bbensten 3-Series (E36) 7 02-27-2005 05:22 PM
yellow pic of engine light on dash means what? ruzo 1,6,7,8 - Series and Mini Cooper 6 07-21-2004 11:11 PM
